Finally a problem with the 3510...
/ Finally a problem with the 3510... #1
Varmintmist
Platinum Member
Chicora, PA
Mahindra3510
... that wasn't caused by me.
Anyone know how much a engine shut off actuator is??
/ Finally a problem with the 3510... #2
Can't help you on price, but are you sure it's the solenoid. Another posting that I've been talking with thinks he has the same issue with a 3215. The last thing I mentioned for him to check in a PM was his key to make sure it's not worn down and to test the ignition switch since it has two position and you need both to get the tractor to start and then to stay running. On the 2815/3215 series you have to pick and hold the load relay to keep fuel to the engine. Maybe this is the same for your tractor before spending money on a solenoid.
0 vdc on the wire connector just in front of the solenoid when the key is in the on position, 12vdc when the key is in the off position.
I guess I could run a hot wire to it to see if the solenoid will actuate, but if it is getting power. it should work.
/ Finally a problem with the 3510... #4
You can find the parts look up on our web site look under engine section then go to engine stop group it is listed there, i sent you a PM with pricing and i have it on the shelf and could ship to you if your interested you can call toll free 866-393-0642 or order your Mahindra parts on line. New England Tractor
part# E575360015 STOP SOLENOID ASSEMBLY
I pmed you back, thanks but I got to the dealer.
I had to noodle the part out when the sol. was energized. I figured out it was normally extended and powered for a few seconds to shut it off. Seems a bit backwards, however it makes more sense because you can still run the tractor without it.
It looks like the 2810 has the same set up and I would guess the 4110 does also since the 3510 and 4110 share the same book.
If your key wont shut her off, check power to the stop solenoid. It SHOULD be 0vdc when the key is on, 12VDC off for about 15 seconds, then 0VDC.
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
Ground Protection Mats (A64194)
Ground Protection...
2018 International WorkStar 7300 2,000 Gallon Water Truck (A64556)
2018 International...
SCAG TIGER MOWER (A64557)
SCAG TIGER MOWER...
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
