FIMCO Sprayer Question
/ FIMCO Sprayer Question #1
Waldo
Utah
John Deere 790 (sold)
I’m thinking about getting the FEMCO 3ph 60 gallon boom sprayer with the PTO pump and hand sprayer from Tractor Supply Co and have a couple of questions.
1) Regarding the PTO pump, what is the difference between a 6 roller and an 8 roller pump? I get the fact one has two more rollers, but what is a roller and why would more of them be better / worse? I have read in other threads to make sure to clean and lube after use, so I will.
2) Can I buy a bushing kit and use this with my i-Match (i-Match is John Deere’s quick hitch system)? If not, how hard are these to put on and take off the tractor? Is there a different manufacture that makes a 3ph model that does work with the i-Match system?
If you have any other thoughts or wisdom to pass on; please do, I need all the help I can get! Thanks in advance.
/ FIMCO Sprayer Question #3
Here is a recent thread on cleaning a roller pump. Click Here In it you will find a link to a manufactures site with pictures of pumps. Unless you are running a boom over 20'. You should not need more than a 6 roller pump.
/ FIMCO Sprayer Question #4
/ FIMCO Sprayer Question #5
I have that sprayer for my 2520 and I-match and it works great. I had to drill a new hole for the top link in the sprayer about 6 inches lower with a 3/4 drill bit. Also, it sits too low on the ground for the i-match to pick up so I set on wood blocks when i'm done. It's the best way for me to spray weeds on 4 acres of lawn.
/ FIMCO Sprayer Question #6
/ FIMCO Sprayer Question #7
I bought a PK sprayer from Rural King after several comparisons with the Fimco. I think the Fimco had a superior boom on it but either one I would end up modifying. The breaker was that the PK was $379 and the fimco was $489 and I was planning to take the torch to either one. I bought Delevan 8 roller pump (versus 6 for pressure) and mounted it under the sprayer with a light weight pto shaft. I dont know if this helps but it is an option. Not to mention the PK was already JD green and yellow
/ FIMCO Sprayer Question #8
/ FIMCO Sprayer Question #9
A Hypro 6500 is a good all purpose pump. The 6500XL is a stainless steel like alloy that is much more resistant to corrosion. See hypropumps.com for details onpumps.
A good pump setup allows you to remove and flush the pump. My setup has a male 3/4 banjo fitting on the discharge hose and 3/4 banjo 90 female for the inlet. After use, flush with soap and water, add antifreeze, and connect the hoses, keeping the antifreeze in the pump, not in the sprayer tank.
For filling the tank I use 1/2 copper in a J hook with a ball valve and also a 3/4 male Banjo. The Banjo is for flushing the pump. Remove the pump from the tractor, connect the Copper j tubing to the female listed above and let the water run the pump for a while.
The silver pump is the stainless steel "silvercast" model i got new off ebay. Still looks like new inside.
/ FIMCO Sprayer Question #10
/ FIMCO Sprayer Question #11
Mt Fimco works fine on a Speeco hitch. You may have to drill two holes.
An XR Teejet size 2 (yellow) is a good overall herbicide spray tip. Get a Teejet catalog and read it. Lots of good stuff.
This is a spray boom I made for my sprayer. The spraye came with a boomless nozzle which was very very poor.
/ FIMCO Sprayer Question #12
/ FIMCO Sprayer Question #13
I can't answer your questions, but I can say that FIMCO has great customer service. I bought a used FIMCO 60g 3pt srayer, and had to replace all the nozzles and hose fittings due to dry rot. Their customer service was great! It was really nice to talk to someone who spoke english, lived in North America, and was very familiar with the products they sell.
Joe
Thanks everyone, the link provided has a lot of good information. All I need to do now is sell my 40 gallon pull behind. My local Tractor Supply Co. only carries the 55 gallon model (the TSC website shows the 60 gallon) but that will do I’m sure.
Informational Lot - Shipping (A63689)
Informational Lot...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2015 Kenworth T680 (A64127)
2015 Kenworth T680...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
