Fimco Spayer Gauge
/ Fimco Spayer Gauge #1
fitzisprint955
Bronze Member
Barneveld. Wisconsin
2305/345GX
The 60 gallon sprayer comes with the 400 psi gauge. I thought this was overkill so I bought a 60 psi gauge and put it on. Well it didnt work so well, it wouldnt stay at anyone pressure. So I put the original one back on and it worked fine. Anyone have this problem? Thanks Fitz
/ Fimco Spayer Gauge #2
My gauge on my little FIMCO 15 GAL shakes a bit but stays
on the same pressure when I adjust enough volume through the pump.
/ Fimco Spayer Gauge #3
Was the 60psi gauge liquid filled? I think they have to be to handle the vibrations of those pumps.
/ Fimco Spayer Gauge #4
Mine is on a three point platform so it gets that tractor vibration too. The idea of a liquid filled gauge is a great idea and I shall take your advice. Thanks.
BD
/ Fimco Spayer Gauge #5
Bigdad,
Your gauge is probably liquid filled if it came on the sprayer. I know mine is. I thought maybe Fitzi replaced the 400psi liquid filled gauge with a standard 60psi gauge. Even my liquid filled gauge shakes somewhat.
Good luck.
1987 Asphalt Tanker Trailer (A65563)
1987 Asphalt...
2012 T/A Frac Blender Trailer (A64194)
2012 T/A Frac...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
New/Unused Wolverine Hydraulic Hay Bale Squeeze (A65583)
New/Unused...
2011 Chevrolet Camaro Coupe (A64194)
2011 Chevrolet...
