Oil & Fuel Filter substitute
   / Filter substitute #1
Jkrph
Kioti CK35SE
Does anyone know of a replacement for the hydraulic filter for a CK3510H? It is part #T2185-38031. The Wix website says there is no comparable filter available.
Thank you.
   / Filter substitute #2
Hydraulic filters are special filters and much different than your average oil filter. They are usually specific to just a few machines and therefor many filter companies don't make filters that are not very common, thus the higher price for these. Just go to your OEM dealer and bite the bullet for your hydraulic filters, and you'll be certain that they are correct for your application. Dutchy
   / Filter substitute #3
Check Baldwin for hydraulic filter, Donaldson for air. That's what I crossed on mine. Donaldson was the OEM air filter on mine, the hydraulic said Daedong, but other than color was exactly same in every way to the Baldwin. I'd bet a Coke Baldwin is the OEM & just has Daedong label for the one that came on the tractor....
https://www.tractorbynet.com/forums...399105-nx4510hst-completed-50-hr-service.html
Your p/n's will obviously be different, but this is what I bought, where I got if from, for my DIY service. And you probably have 2 hydraulic filters.....mine does. One I got a Wix, the other Baldwin.
   / Filter substitute #4
Thank you.
I bet your local Kioti dealer has them in stock.
   / Filter substitute #5
The above is good advice, no good jeopardizing the operation of your hydraulics to save a few dollars, starve the pump and cause damage and you will wish you had purchased the OEM filter.
   / Filter substitute #6
Hey guys looking for the cross reference for the hydro and trans filter for my 2016 kioti 2610HST I would prefer a Baldwin number if can.
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52128)
2004 Capacity Yard...
