Oil & Fuel Filter substitute
/ Filter substitute #1
Jkrph
Kioti CK35SE
Does anyone know of a replacement for the hydraulic filter for a CK3510H? It is part #T2185-38031. The Wix website says there is no comparable filter available.
Thank you.
/ Filter substitute #2
Hydraulic filters are special filters and much different than your average oil filter. They are usually specific to just a few machines and therefor many filter companies don't make filters that are not very common, thus the higher price for these. Just go to your OEM dealer and bite the bullet for your hydraulic filters, and you'll be certain that they are correct for your application. Dutchy
/ Filter substitute #3
Check Baldwin for hydraulic filter, Donaldson for air. That's what I crossed on mine. Donaldson was the OEM air filter on mine, the hydraulic said Daedong, but other than color was exactly same in every way to the Baldwin. I'd bet a Coke Baldwin is the OEM & just has Daedong label for the one that came on the tractor....
https://www.tractorbynet.com/forums...399105-nx4510hst-completed-50-hr-service.html
Your p/n's will obviously be different, but this is what I bought, where I got if from, for my DIY service. And you probably have 2 hydraulic filters.....mine does. One I got a Wix, the other Baldwin.
/ Filter substitute #4
Thank you.
I bet your local Kioti dealer has them in stock.
/ Filter substitute #5
The above is good advice, no good jeopardizing the operation of your hydraulics to save a few dollars, starve the pump and cause damage and you will wish you had purchased the OEM filter.
/ Filter substitute #6
Hey guys looking for the cross reference for the hydro and trans filter for my 2016 kioti 2610HST I would prefer a Baldwin number if can.
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR4AJ276527 (A61165)
2010 International...
UNUSED KJ 46'X25' METAL GARAGE (A62131)
UNUSED KJ 46'X25'...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
UNUSED WOLVERINE SB72-72" ROCK BKT (A62131)
UNUSED WOLVERINE...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
