Oil & Fuel Filter substitute
/ Filter substitute #1
Jkrph
Kioti CK35SE
Does anyone know of a replacement for the hydraulic filter for a CK3510H? It is part #T2185-38031. The Wix website says there is no comparable filter available.
Thank you.
/ Filter substitute #2
Hydraulic filters are special filters and much different than your average oil filter. They are usually specific to just a few machines and therefor many filter companies don't make filters that are not very common, thus the higher price for these. Just go to your OEM dealer and bite the bullet for your hydraulic filters, and you'll be certain that they are correct for your application. Dutchy
/ Filter substitute #3
Check Baldwin for hydraulic filter, Donaldson for air. That's what I crossed on mine. Donaldson was the OEM air filter on mine, the hydraulic said Daedong, but other than color was exactly same in every way to the Baldwin. I'd bet a Coke Baldwin is the OEM & just has Daedong label for the one that came on the tractor....
https://www.tractorbynet.com/forums...399105-nx4510hst-completed-50-hr-service.html
Your p/n's will obviously be different, but this is what I bought, where I got if from, for my DIY service. And you probably have 2 hydraulic filters.....mine does. One I got a Wix, the other Baldwin.
/ Filter substitute #4
Thank you.
I bet your local Kioti dealer has them in stock.
/ Filter substitute #5
The above is good advice, no good jeopardizing the operation of your hydraulics to save a few dollars, starve the pump and cause damage and you will wish you had purchased the OEM filter.
/ Filter substitute #6
Hey guys looking for the cross reference for the hydro and trans filter for my 2016 kioti 2610HST I would prefer a Baldwin number if can.
UNUSED 2026 INDUSTRIAS AMERICA 5'X10' HYD DUMP TRL (A62130)
UNUSED 2026...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
UNUSED CFG INDUSTRIAL MH12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
2017 Chevrolet Equinox SUV (A61569)
2017 Chevrolet...
429136 (A61166)
429136 (A61166)
500 Gallon Pull Behind Sprayer (A61166)
500 Gallon Pull...
