Filter screen for L2800
/ Filter screen for L2800 #1
bama85
Lexington, KY
L2800, M7040, ZD21
I've been reading several posts regarding filter screens needing to be cleaned when changing oil. I preformed my 50hr service a few weeks ago and I still don't know what the filter screen is and where to find it. Can someone please help. I did notice two small shards of metal that ended up in my hand when I pulled the two oil drain plugs. If there is a filter screen how do I find it and clean it properly. Thanks ya'll
/ Filter screen for L2800 #2
I do not believe that the L2800/L3400 have these filter screens.
/ Filter screen for L2800 #3
I believe there is a strainer for the HST. If yours is a gear model it will not have it. On my old B series it was a big hex head (bolt) behind the right rear tire. My owners manual showed where to locate it.
Thanks guys, It is a gear drive so probably no filter screen. I can rest easy now. Regards.
/ Filter screen for L2800 #5
Dont rest to long: left side in front of rear axle housing looks like oblong flat piece of metal with two bolts holding it on i think 10mm wrench or 12mm for removing bolts. But only remove it when fluids is drained its about 6'' long when removed!!!!
/ Filter screen for L2800 #6
I will have to look on the tractor, I can't find on my parts breakdown. an I sure did not clean it during my 50 hour service.
/ Filter screen for L2800 #7
I'd be surprised if that was correct. Every manual I've seen shows a filter or two somewhere. Here for example in this BX2200 its behind the diff. (Part 030). But you could be correct - I really don't know.
  • Pages from BX2200d.pdf
/ Filter screen for L2800 #8
I'll go through my owners manual again today but I never thought that there was anything that said "clean filter screens" at any interval.
Any other L2800/L3400 owners know anything about this?
/ Filter screen for L2800 #9
The L2800 HST has two filters one on each side of the transmission case. Both are external canister type filters. One hydraulic low pressure (right side), one HST high pressure filter (left side). No screens that I can find.
/ Filter screen for L2800 #10
I have changed the the HST filters on my L2800HST twice now and the manual never mentions any filter screens like what was on the B7500 I previously owned.
/ Filter screen for L2800 #11
I have the L2800 geared,the only filters to change are the hydraulic filter,part number 3A431-82623,and the oil filter part number 70000-74035. Both Kubota part numbers.
/ Filter screen for L2800 #12
Now you've got me worried, I bought an HST filter and the necessary fluids for my change. I only saw one HST filter listed in the manual, do I need to look for another one on the other side?
In regards to other posts here, I don't believe there is filter screen anywhere.
/ Filter screen for L2800 #13
There are two filters. The HST filter under the left platform, and the hydraulic filter on the right side under the platform. The HST filter can be change without much fluid loss. The hydraulic filter will almost drain the sump.
The factory filters are painted the same color as the tractor.
20ft Driveway Gates (A65579)
20ft Driveway...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
2000 Komatsu D61PX-12 (A64126)
2000 Komatsu...
