Filter difference on 425
/ Filter difference on 425 #1
jfischer
Manassas, Virginia
Hustler X-One, Power Trac 425, Sold and Retired my JD318
It is about time to do my first oil change on the 425, and I picked a filter up when I was down in Tazwell when I picked the machine up.
I was looking on the net for some more to purchase, as they are usually cheaper when you buy a few at a time.
I am trying to figure out what the difference is with the 248-65801-10 which is what they sold me and is listed in the parts break down for the EH72 engine. Many places seem to point you to a 248-65801-00 which is listed for the EH64 EH65 and other engines.
I am wondering if the one number difference is because the one is for the models that screw straight to the block, where the EH72 has the remote place (for a lack of the correct name) with the sensor on it.
Just would like to get the correct filter, if there is any difference. Especially since the engine is new.
Ok, since I have not gotten any answers here, where filters are most of you using on your 425? Maybe that would have been a better way of putting it.
/ Filter difference on 425 #3
Robin/Subaru EH72 Parts Diagrams for Oil Cooler/Oil Filter
Click on oil filter assembly price.
Excerpt:
This part replaces obsolete part #: and 248-65801-00.
The -10 replaces the -00
/ Filter difference on 425 #4
Why genuine Kohler, of course! :D
I looked up the specs on those two numbers you supplied. One talks about PSI rating, internal bypass, etc... and the other does not. And, as J_J mentioned, it looks like the part number has changed to a newer number.
Have you tried looking at Jack's Small Engines?
Lawn Mower Parts
/ Filter difference on 425 #5
There is a Fram wholesale business near me and I talked to him about the Robin/Subaru filters to see if Fram matched any of them. He done some searching and found one that he believes is going to work, but he cautioned me to inspect it very closely when putting it on. I don't even have 4 hours on my PT yet, so its going to be a while before I try the filter out to see if it works.
Thanks JJ, I seem to be able to find a lot of generic for the one number, but not the other, (which I guess is the newer number they are selling now)
Since it is new and still under warr. I will try to stick with the correct number on it.
M R, I think I will just go ahead and buy the correct filter (which is still a lot more then I feel a small filter like that should be) but about $6 or $7 less then what I paid for the first one when I picked the tractor up.
I will get 4 or 5, then I should be set for a year or two with it.
Josh, I am going to stick with the Subaru one. Penny here or there shouldn't hurt me.
So, just what is the hold up with putting a few hours on yours. I am right at 20 and going to change it in the next day or so.
Have you tried any of those new attachments you got yet?
/ Filter difference on 425 #9
I have a kohler on a lawn tractor and use the Napa / Wix filter. It is a very common filter type and appears on a number of other machines in my stable. What is interesting to me was that there was a small, medium and large choice for my machine. All tech specked the same, just longer (more oil capacity).
I now have 4 of the filters on the way that came on the machine now, plus the one I bought when I picked the machine up. That should last me for a year or two.
Now to get it changed, and the filter out without getting it all over everything. Wish there was more room down in the tub. I can see there is a hair of wetness from something down in there now, and I checked all and cleaned it up when I bought it, so something has to have a hair of a leak, (seems just enough to make you wonder what it is) but guess I will have to live with that, until the engine ever has to come out.
/ Filter difference on 425 #11
Put a zip lock bag over the filter from below before unscrewing it, bunching up the extra bag near the top of the filter. All the oil overflow goes in the bag. No mess.
Wish there was a handhold in the back of the tub that I could actually get my arm into without causing much pain. Power Trac definitely wasn't think maintainability when they sized the tub and position the components.
Thanks for the advice on the bag, I have big hands and looks like it might be easier to get in there if I take the heat shield off also.
I am like you, and would have been nice if they would have made the tub a hair bigger to do things.
Wish there was a handhold in the back of the tub that I could actually get my arm into without causing much pain. Tormach definitely wasn't think maintainability when they sized the tub and position the components.
/ Filter difference on 425 #13
Through the week I go to watchmaker school in the city of York, so on the weekends I drive back home and just don't have much time to spend on the machine. The hand controls are just about finished.
The nice thing with finding out if this Fram filter works is that I will be able to go with a FRAM Tough Guard filter. I used a regular FRAM filter on my Steiner 30 HP for about 200 hrs and then the FRAM dealer said all he had in was the Tough Guards in that size, so although reluctant , I bought one. WOW! That engine can be ran for about 30 hrs and the oil still looks like it was just changed! Sometime I would like to check the micron rating on it.
/ Filter difference on 425 #14
Which filter did you use? I am three hours from an oil change and out of spares. Sorry i see you have not found one
/ Filter difference on 425 #15
The FRAM dealer thinks this filter size will work, but cautioned me to make sure it fits properly. So, I haven't tried it out yet, but the FRAM number is PH4967.
/ Filter difference on 425 #16
If the FRAM PH4967 works, then the higher quality one I was saying about (FRAM Tough Guard) will be part number TG4967.
/ Filter difference on 425 #17
I'm really curious now to see if this PH4967 filter works now, because to my amazement they FRAM also makes a synthetic oil filter to match that number.
/ Filter difference on 425 #19
Watch Making School? I read a great article on watch making in Popular Mechanics.... Not my skill set for sure.
/ Filter difference on 425 #20
Haha! Yeah, its painfully delicate work. Some of the pivots on a watch arbor (axle) that fit into a jewel are literally the thickness of a hair and can break if dropped, then you need to find or make one.
