Filter Cross References Jinma 284
   / Filter Cross References Jinma 284 #1
markh1
Story City, IA
2003 Jinma 284LE Y385T
I found these cross reference numbers on a couple of different sites.
Oil Filter - NAPA 1516
Fuel Filter - NAPA 3195
Air Filter - NAPA 2276
I was changing oil and the filter doesn't fit. I went to NAPA website and it says Oil Filter Thread Size (inches) : 3/4 - 16. Any help would be appreciated.
Mark H
   / Filter Cross References Jinma 284 #2
I use a Fram PH3950 on my tractor with a 2003 build date.
Chris
Cris,
That filter has metric threads to fit?
Mark H
   / Filter Cross References Jinma 284 #5
Here are all the filters I use on mine. Its a 2003 and have used these filters since day 1.
Air= Purulator A42019
Oil= Fram PH3950
Fuel= Fram P6503
Chris
   / Filter Cross References Jinma 284 #6
Here are the alternatives that I use on my 284.
RonJ
Thanks for the info. Went to NAPA and got the 1381 oil filter.
Mark H
   / Filter Cross References Jinma 284 #8
So did it work? Don't leave us all in suspense.
Chris
Don't know if it works or not. I am at work and won't know until tomorrow.
Mark H
Chris,
Yes the NAPA filter fit. Thanks for the info.
Mark H
   / Filter Cross References Jinma 284 #11
Glad it worked. The other numbers I listed for the fuel and the air filter should also work.
Chris
   / Filter Cross References Jinma 284 #12
i have a 204 nortrac the oil filter i use is a napa 1626, not sure if that will work in yours.
   / Filter Cross References Jinma 284 #13
Hi guys,
I used that Napa 1381 oil filter for on Loretta's 284 which has 20 X 1.5mm threads.
I found a Baldwin (B202) cross over with 20 x 1.5mm threads. It's a little larger in diameter and a lot taller. It fits perfectly on her Jinma and has a lot more filtration surface I believe.
Click here for the specs on it: Baldwin B202 Oil Filter Specs
But I didn't buy it from that link.
I found a much better price on this link: Icon Heavy Duty Baldwin B202 Filters
I bought a case of 12 filters for $5.74 each.
Below are some photo comparisons of the stock filter and the Baldwin B202. Also one showing the stock filter, a Napa filter (2nd line) and the Baldwin B202 filters. They all have the 20x1.5mm thread.
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2023 KRT ST650 STAND-ON SKID STEER (A60429)
2023 KRT ST650...
UNUSED FUTURE FTH50-(50) SHEETS OFGALVALUME (A60432)
UNUSED FUTURE...
iDrive TDS-2010H...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
