Filter Cross References Jinma 284
/ Filter Cross References Jinma 284 #1
markh1
Story City, IA
2003 Jinma 284LE Y385T
I found these cross reference numbers on a couple of different sites.
Oil Filter - NAPA 1516
Fuel Filter - NAPA 3195
Air Filter - NAPA 2276
I was changing oil and the filter doesn't fit. I went to NAPA website and it says Oil Filter Thread Size (inches) : 3/4 - 16. Any help would be appreciated.
Mark H
/ Filter Cross References Jinma 284 #2
I use a Fram PH3950 on my tractor with a 2003 build date.
Chris
Cris,
That filter has metric threads to fit?
Mark H
/ Filter Cross References Jinma 284 #5
Here are all the filters I use on mine. Its a 2003 and have used these filters since day 1.
Air= Purulator A42019
Oil= Fram PH3950
Fuel= Fram P6503
Chris
/ Filter Cross References Jinma 284 #6
Here are the alternatives that I use on my 284.
RonJ
Thanks for the info. Went to NAPA and got the 1381 oil filter.
Mark H
/ Filter Cross References Jinma 284 #8
So did it work? Don't leave us all in suspense.
Chris
Don't know if it works or not. I am at work and won't know until tomorrow.
Mark H
Chris,
Yes the NAPA filter fit. Thanks for the info.
Mark H
/ Filter Cross References Jinma 284 #11
Glad it worked. The other numbers I listed for the fuel and the air filter should also work.
Chris
/ Filter Cross References Jinma 284 #12
i have a 204 nortrac the oil filter i use is a napa 1626, not sure if that will work in yours.
/ Filter Cross References Jinma 284 #13
Hi guys,
I used that Napa 1381 oil filter for on Loretta's 284 which has 20 X 1.5mm threads.
I found a Baldwin (B202) cross over with 20 x 1.5mm threads. It's a little larger in diameter and a lot taller. It fits perfectly on her Jinma and has a lot more filtration surface I believe.
Click here for the specs on it: Baldwin B202 Oil Filter Specs
But I didn't buy it from that link.
I found a much better price on this link: Icon Heavy Duty Baldwin B202 Filters
I bought a case of 12 filters for $5.74 each.
Below are some photo comparisons of the stock filter and the Baldwin B202. Also one showing the stock filter, a Napa filter (2nd line) and the Baldwin B202 filters. They all have the 20x1.5mm thread.
2018 Honda Odyssey Van (A59231)
2018 Honda Odyssey...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A61165)
2005 Ford F-450...
2012 Chevrolet Traverse LT SUV (A59231)
2012 Chevrolet...
