Oil & Fuel Filter cross reference / help
/ Filter cross reference / help #1
nvip9r
Mass
Kioti CK30
Looking for a little help for cross referenceing filters. I have a NAPA/Kubota dealer 1 minute down the road, but we own a "new to us" 2005 CK30 GEAR tractor, and love it. Now time to do a little maintence. Want to change out the filters and did some searching on line and noticed people are using a NAPA/WIX filters and seem to be happy. Is there anything to worry about with a change from the Kioti brand? Looking at prices they seem cheaper than the Kioti, and also nearest Kioti is a nice long ride away. I know I can order on line but was thinking might be good to have a local dealer for the filters. Looking for all for the CK30 Gear.
So if anyone has some numbers would be great or even some input. I'd appreciate it a ton...
Also are the manuals (parts/workshop) worth it for the maintence?
Thanks
Nick
Going to do some searching but thanks for any help.
/ Filter cross reference / help #2
I use Kioti filters on my CK30hst. I just order from Wallace and keep an extra set on the shelf. There have been past posts with some cross numbers. Some use aftermarket and others stick to Kioti. I'm sure your napa dealer can make the cross.
Routine maintenance doesn't need the mauals but they sure do help with everything else. I used the workshop manual to diagnose my faulty fuel sending unit by knowing the resistance numbers. The parts manual gives full diagrams so you know what's there. If you plan on keeping it and want to do your own repairs if the time comes, then they're worth having for the cost.
/ Filter cross reference / help #4
Fuel filter Wix #33507 Napa #3507
Oil filter Wix #51324 Napa #1324
My DK 35 takes the same filters. I have used them several times and they work fine.
/ Filter cross reference / help #5
Just bought an engine oil filter. Napa # 1626, this is for my 2008 CK35 HST.
You don't want to use the 1626. Its a smaller filter and it has a lower bypass pressure then the 1324 which is the correct filter. The 1626 has an 8-11 psi bypass and the 1324 has a 16 psi bypass.
1626Part Detail
1324Part Detail
/ Filter cross reference / help #6
Has any one noticed Napa oils filters are differnet numbers for oil for Mousefield and DK35vince, one has DK 35 the other CK 35, and original request was for a CK 30, do they all use same filter?:confused:
/ Filter cross reference / help #7
1324 is the correct number. Follow the link to the part detail and view all applications. The filter fits DK's and CK's.
Carquest also has the same filters only they start with 85 but use the same final 3 numbers. For oil it would be 85324.
/ Filter cross reference / help #8
Search Results On WIX filters, WIX oil filters, WIX air filters, WIX fuel filters, WIX Heavy Duty Oil Filters , found site thanks to SunnyJim links
Part Part No. Filter
Loc. Engine VIN Code Model Comment
Air Filter 46489 CK30 w / Daedong 3A150 Series Engines CK30 E723011081
Air Filter 46489 CK30H w / Daedong 3A150 Series Engines CK30H E723011081
Fuel Filter 33507 CK30 w / Daedong 3A150 Series Engines CK30 8461243160
Fuel Filter 33507 CK30H w / Daedong 3A150 Series Engines CK30H 8461243160
Oil Filter 51324 CK30 w / Daedong 3A150 Series Engines CK30 E620132443
Oil Filter 51324 CK30H w / Daedong 3A150 Series Engines CK30H E620132
/ Filter cross reference / help #9
I got the 1626 number from my dealer. I will look at the 1324. I have 195 hours on the CK35 and will be doing the oil/ filter in the next week or two. Thanks SunnyJim for pointing out the better filter to use. :thumbsup:
Thanks. I was thinking it might be cheaper to get the NAPA filters, but looks like Wallace sells them reasonable priced. Any suggestions on Hydraulic Oil? The tractor has run Shell Rotealla 15w40 from Walmart and no issues. Figured keep running that. Thanks again
Will be putting an order in at Wallace very soon. thanks
/ Filter cross reference / help #11
Stick with a name brand and you will have no worries.:thumbsup:
/ Filter cross reference / help #12
I use the Shell Rotella but 5W40 weight. It makes for nice starts when it's single digit temps. Works good in Summer too.
Thanks to all for the filter numbers in case I need one fast.
/ Filter cross reference / help #13
Exchanged my engine oil filter at Napa today. The 1324 is longer than the 1626, cost in Canadian $14.10 which includes taxes and environmental charges. Not that practical to go to the closest Kioti dealer as he is over 2 hours drive away. :)
/ Filter cross reference / help #14
I'm new to Kioti, having just bought a CK30HST. A couple refs above to "Wallace" for ordereing filters. Can someone give me the web site?
How about the hydralic and transmission filters? Any cross refs for these?
/ Filter cross reference / help #16
So I used this thread and bought a NAPA 1324 oil filter for my Kioti CK30 with 902 hours on it. Well it went on and seems to work but be warned, the NAPA filter is much taller than the OEM and sits within 1/4" of the side engine cover. And, oh the horror, it's white. Which is actually pretty nice so that I can write on it the date and hours on the machine for future reference.
2024 BIG TEX 102" X 25' GOOSENECK TRAILER (A65054)
2024 BIG TEX 102"...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A65563)
2005 Ford F-450...
John Deere RM 12R Cultivator (A66285)
John Deere RM 12R...
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
2013 WYLIE WATER TRAILER (A65643)
2013 WYLIE WATER...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
