Filter changes and now fuel issues.
/ Filter changes and now fuel issues. #1
Eric1973
Northern Idaho
Ford 1720 2010 Branson 4720H
Changed out all the filters on my 4720H.
After I installed the fuel filter the tractor will start and run, but after a couple minutes it will lose RPMs and die, but I can start it right back up pretty easily.
I've tried flushing all the air out of the bowl and the injector lines.
I installed the PF981 filter from Baldwin Filters this time around..
Any ideas on what I should be checking?
Thanks..
/ Filter changes and now fuel issues. #2
Thanks..
If there was a problem BEFORE you changed the filter,you neglected to tell us. Details are important when asking for help long distance.
Clear that up before we commence guess-t-mating.
Jaxs, There wasn't a problem before, just changing the filter for maintenance.
/ Filter changes and now fuel issues. #4
Then your problem must be from the new filter. Either it sill has air or it's not quite the right filter.
On the other hand, the tractor does have an electric lift pump. Just leaving the key in the On position will run the pump and should take all the air out.
/ Filter changes and now fuel issues. #5
Did you put in the o rings in right......
the outlet side of the filter housing was leaking air.
Ended up taking the housing off, used a punch to spread the nipple a little bit and then re set it into the housing.
Just ran it for about an hour moving some dirt, skid a log into the landing and moved some logs around in the landing area.
Thanks for taking the time to reply to my thread guys.
/ Filter changes and now fuel issues. #7
Nice........
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
John Deere 1025R (A53317)
John Deere 1025R...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
