Filter back pressure
/ Filter back pressure #1
6sunset6
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I have a rather long post in "build it yourself" about a log splitter. But the question I have is better asked here.
16 gpm pump 18 gal res BIG Filter in the return line Wix 51759 30gpm 10u paper element spin on.
Iso 46 hyd oil around 40d F outside
When I start up the pump the filter is in bypass 25psi and after a bit it drops to zero or close to it. Temperature gage on the res has not even moved after an hour of running.
Question is why does the filter bypass for maybe 10-15 min?
/ Filter back pressure #2
Perhaps the thick cold oil will not pass through as well as when warm and a little thinner.
/ Filter back pressure #3
+1 on what JJ said. ISO 46 at 40 degrees is kind of thick and after operating for a few minutes the oil in the element starts flowing and your gauge drops. Pretty typical for a cool/cold weather start.
/ Filter back pressure #4
If you want to heat up the tank fluid, hold the valve in extended operation until the fluid is warm. You really don't want the filter to bypass for very long. The relief will pass fluid as long as you hold the lever.
2012 Gastron 18ft Boat w 18ft S/A Boat Trailer. (A61574)
2012 Gastron 18ft...
generator trailer (A61569)
generator trailer...
2021 Chevrolet Equinox SUV (A61574)
2021 Chevrolet...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
