Filter back pressure
/ Filter back pressure #1
6sunset6
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I have a rather long post in "build it yourself" about a log splitter. But the question I have is better asked here.
16 gpm pump 18 gal res BIG Filter in the return line Wix 51759 30gpm 10u paper element spin on.
Iso 46 hyd oil around 40d F outside
When I start up the pump the filter is in bypass 25psi and after a bit it drops to zero or close to it. Temperature gage on the res has not even moved after an hour of running.
Question is why does the filter bypass for maybe 10-15 min?
/ Filter back pressure #2
Perhaps the thick cold oil will not pass through as well as when warm and a little thinner.
/ Filter back pressure #3
+1 on what JJ said. ISO 46 at 40 degrees is kind of thick and after operating for a few minutes the oil in the element starts flowing and your gauge drops. Pretty typical for a cool/cold weather start.
/ Filter back pressure #4
If you want to heat up the tank fluid, hold the valve in extended operation until the fluid is warm. You really don't want the filter to bypass for very long. The relief will pass fluid as long as you hold the lever.
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
Pat's QH and hydraulic top-link.
Pat's QH and...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
