Filter back pressure
   / Filter back pressure #1
6sunset6
Veteran Member
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I have a rather long post in "build it yourself" about a log splitter. But the question I have is better asked here.
16 gpm pump 18 gal res BIG Filter in the return line Wix 51759 30gpm 10u paper element spin on.
Iso 46 hyd oil around 40d F outside
When I start up the pump the filter is in bypass 25psi and after a bit it drops to zero or close to it. Temperature gage on the res has not even moved after an hour of running.
Question is why does the filter bypass for maybe 10-15 min?
   / Filter back pressure #2
Perhaps the thick cold oil will not pass through as well as when warm and a little thinner.
   / Filter back pressure #3
+1 on what JJ said. ISO 46 at 40 degrees is kind of thick and after operating for a few minutes the oil in the element starts flowing and your gauge drops. Pretty typical for a cool/cold weather start.
   / Filter back pressure #4
If you want to heat up the tank fluid, hold the valve in extended operation until the fluid is warm. You really don't want the filter to bypass for very long. The relief will pass fluid as long as you hold the lever.
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2015 INTERNATIONAL DURASTAR 4400 WATER TRUCK (A53843)
2015 INTERNATIONAL...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53473)
2011 New Holland...
safety baskets (A53421)
safety baskets...
