Filling L2350DT Transmission
   / Filling L2350DT Transmission #1
bpicard
Houston, TX
L2350DT
How can I tell my transmission is filled?
I removed the fill cover and can't see the level.
Thanks.
Brian.
Kenny,
You are right. Thanks.
I am having trouble with my bucket drifting down. Seems like I have a worn cylinder or something.
Thanks.
Brian.
   / Filling L2350DT Transmission #4
Brian
I would suspect the control valve, are the cylinder hoses quick couple at the valve? If they are you can switch the lift with the curl circuit and see if the problem stays the same. If it changes to the other circuit it is the control valve. KennyV.
   / Filling L2350DT Transmission #5
Is it drifting down while in use or just leaking down when the tractor is off. Mine has always leaked down, but very slowly, when the tractor is off. It does not drift at all while running.
   / Filling L2350DT Transmission #6
Welcome Brian, I have the same model and did all the fluids when I received
my tractor. There is also a screen filter/strainer to remove and clean if you are going to drain and refill. I ordered the maintenance manual from a local tractor dealer, pretty handy. There are quite a few drain plugs to remove to do a thorough draining, but make sure to be on a hard level surface to get an accurate reading on the trannny fluid level
   / Filling L2350DT Transmission #7
If the 2350DT (4wd) is like my 2500 there should be 3 drains for the hydraulic/gear oil. There is 4 on my 4wd.
Rob
Gent's,
Thanks very much for all the help.
This is a great board because of people like you.
Brian.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2015 Ford Transit 250 Cargo Van (A50323)
2015 Ford Transit...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2014 Toro Workman HD Utility Cart (A51691)
2014 Toro Workman...
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
International Tractor w/Belly Mower (A50774)
International...
