Filling L2350DT Transmission
   / Filling L2350DT Transmission #1
bpicard
Houston, TX
L2350DT
How can I tell my transmission is filled?
I removed the fill cover and can't see the level.
Thanks.
Brian.
Kenny,
You are right. Thanks.
I am having trouble with my bucket drifting down. Seems like I have a worn cylinder or something.
Thanks.
Brian.
   / Filling L2350DT Transmission #4
Brian
I would suspect the control valve, are the cylinder hoses quick couple at the valve? If they are you can switch the lift with the curl circuit and see if the problem stays the same. If it changes to the other circuit it is the control valve. KennyV.
   / Filling L2350DT Transmission #5
Is it drifting down while in use or just leaking down when the tractor is off. Mine has always leaked down, but very slowly, when the tractor is off. It does not drift at all while running.
   / Filling L2350DT Transmission #6
Welcome Brian, I have the same model and did all the fluids when I received
my tractor. There is also a screen filter/strainer to remove and clean if you are going to drain and refill. I ordered the maintenance manual from a local tractor dealer, pretty handy. There are quite a few drain plugs to remove to do a thorough draining, but make sure to be on a hard level surface to get an accurate reading on the trannny fluid level
   / Filling L2350DT Transmission #7
If the 2350DT (4wd) is like my 2500 there should be 3 drains for the hydraulic/gear oil. There is 4 on my 4wd.
Rob
Gent's,
Thanks very much for all the help.
This is a great board because of people like you.
Brian.
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A52748)
2023 NEW HOLLAND...
2202 (A51691)
2202 (A51691)
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2011 JCB 515-40 Telehandler (RUNS) (A50774)
2011 JCB 515-40...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
