Filled tire problem
   / Filled tire problem #1
DustyOne
Today, I tried to dig into a pile of loam, but my tractor just couldn't do it. I then tried to go up a slight incline, but the tractor just didn't move. Thinking that it might be low on hydraulic fluid, I added a little to bring it up to the full mark. It took only a pint, not enough to make a difference. I was totally baffled and thought that the transmission had gone bad. A neighbor stopped by while I was having these problems and he noticed that the tire was staying stationary, but the rim was spinning inside of the tire. The tires are filled with the non toxic "beet juice" known as Rim Guard. . I put additional air into the tire hoping to seal the bead, but it didn't help. The tire isn't leaking, but the rim justs spins on the tire bead. Any suggestions how to remedy this problem? thanks
   / Filled tire problem #3
I have never worked with RimGuard, but I would jack the wheel up off of the ground. Then try to put air in it. That way there is a better chance that the bead will come in contact with the rim and take air.
   / Filled tire problem #4
   / Filled tire problem #5
Scary. I have never heard of this happening but have always worried about it where the rim is much smaller than the tire outside diameter. I imagine this is the case in your instance and that your tires are tubeless. Maybe rimguard is agood lubricant and it has worked into the tire bead area. You are going to have to dismount, completely clean and dry the tire,and remount to establish good bead contact. I dont know how to keep it from happening again other than install a tube. /forums/images/graemlins/tongue.gif
Larry
   / Filled tire problem #6
Larry
   / Filled tire problem #7
Harry welcome to TBN, I'm curious what make of tractor are you having a problem with? Do you know if your tires are tubeless?
   / Filled tire problem #8
   / Filled tire problem #9
I've run RimGuard for 4 years in my TN with 16.9x30 R1's and push them hard. Have never had any slippage problems but then I do run them at rated air pressure. I don't play the games that some here do with varing air pressure.
Andy
   / Filled tire problem #10
Andy
2014 COTTRELL CX-09LS2 AUTO HAULER (A52576)
2014 COTTRELL...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
CATERPILLAR V50B STRAIGHT MAST FORKLIFT (A51246)
CATERPILLAR V50B...
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
