Filled tire leaking
/ Filled tire leaking #21
Per Goeduck: "making it ideal for filling agricultural implement tires as a liquid ballast"
You kidding me?
"Ideal" ..... bah humbug!
CaCl is from days of old!
It will rot/corrode your steel wheels.
The preferred product of modern times is "beet juice" (expensive).
Windshield washer (methanol mix) fluid is a much less expensive option, though it weighs 2+ lbs./gal. less than either "beet juice", or CaCl.
Agree. My post was just how wikipedia.com described it. I don’t know that it would damage his jacket which was the question. Unless I guess he has a full metal jacket :D
/ Filled tire leaking #22
CaCl is actually still used quite often but small tractors use beet juice as they don't need so much fluid. Tubes are worse than tubeless. The oxygen in water is in the compound H2O and is not free oxygen. According to tire companies Firestone and Titan (which also includes Goodyear in the USA) unprotected areas of the rim will only get flash rust before free oxygen is depleted. Tubes tires are prone to slipping under high torque which can damage a tube stem causing a leak. Free oxygen can get into the tire around the stem hole and rust out rims. I've seen older tractors with the rim completely eroded from rust - all tube equipped.
If you didn't get a fluid compatible gauge it will rust. The proper way to check fluid filled tires is with the stem at 12, then press the core to let the fluid blast out so you get air to check. Inflation pressures are the same for fluid except the Tire & Rim Association says the weight of liquid ballast needs to be included in machine weight.
I got liquid gauge from Tractor supply. Thw tire should say tube or tubless. Will look again.
/ Filled tire leaking #24
Many tubeless tires are retrofitted with tubes particularly front tires. My old 5030 Ford was a 1994 and it had tubeless rears and tubed front tires. Liquid filled rears but I never knew what it was they were filled with and those rear tires were original and still holding air when I traded it this past fall. The front tires had seen many a new tube. And a couple of new tires. Almost every time I bush hogged I had to fix one of those darn things. I do not miss them. Three ribbed ag tires.
I am lucky. Been using this like a 4 wheeler. Spends most of the time in the woods.
Can I tell by valve stem, if tube or tubeless?
As for jacket, I washed it. Last American carhartt.
Bobcat SC72 (A64126)
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2016 Freightliner Columbia 120 Glider Truck, VIN # 3ALXA7CG9GDGZ6492 (A65563)
2016 Freightliner...
60 Traffic Cones (A65579)
60 Traffic Cones...
2014 FORD F-150 (A65643)
2014 FORD F-150...
