Filled the rears on BX1500
/ Filled the rears on BX1500 #1
Dman
Moody, AL
Kubota BX1500
Yesterday I filled the rear tires on my BX1500. I used winter formula windshield washer fluid and did a rough calculation beforehand to figure out how much I needed. Well, my math must have been off because I figured I'd need about 5 gallons per tire and ended up having to go get some more because it took a little over 9 gallons per tire. I know it is a little lighter than just water but I'm guessing that should be a little over 70lbs per tire. Not too shabby for the little tires on the BX1500.
I purchased the tire filling adapter at the local NAPA for about $18 and a drill operated pump at Lowes for around $6. I made two short pieces of hose from an old garden hose and some male and female hose ends I also got from Lowes. It took a little longer than I thought it would but I think that's mostly due to the battery powered drill I was using. A corded drill probably would have made the job a lot faster.
I haven't had a chance to test it out since filling them but I'll post my thoughts as soon as I do. It should make it feel a lot more stable mowing across the hill by our driveway and also doing loader work.
/ Filled the rears on BX1500 #2
I haven't filled any tires yet, but for pumping antifreeze into the lines in my campground and into some trailers I winterize, I just use a utility pump in a 5 gallon bucket and just pour the antifreeze in. I even have a manifold made up so I can alternate between antifreeze and air. My point being, why wouldn't this work for filling tires? I probably will be doing mine sometime.
I'm sure that would work and probably be a lot faster than the drill pump that I used. You would just have to have the adapter to fit onto the valve stem of the tire. Like I said I got mine at NAPA. One end is a female garden hose and the other screws onto the valve stem. It also has a button on top that you press to relieve the pressure in the tire. You have to do this every so often when filling.
2014 Ford Explorer SUV (A61569)
2014 Ford Explorer...
Club Car (A59231)
Club Car (A59231)
Case skid steer wheels and tires (A61307)
Case skid steer...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2017 Terex RL4 S/A Towable Light Tower (A60352)
2017 Terex RL4 S/A...
