Field Boss 254
/ Field Boss 254 #1
dmk
We just purchased a Field Boss 254 (believe made by Jinma). It's a nice little tractor starts easy runs good. Only issue is that the PTO is not engaging (we knew and got a good deal on it).
I can't seem to find any info/diagrams/manuals. I know they were made under several names. Can anyone point me to info?
Thanks.
/ Field Boss 254 #2
Try Tommy at Affordable Tractors (he is very active in these forums) he has parts and manuals for just about anything Jinma. There are 2 selector levers I believe on the Jinma. 1 selects the speed the other is engage / disengage. make sure you have them both selected. Also when you move the levers check that the shaft actually rotates it has been known that problems like your has been caused by a broken roll pin.
/ Field Boss 254
Sounds good. I saw lots of posts from him. I will check for both levers tonight. And thanks for the info
/ Field Boss 254 #4
The one lever, I believe, is marked "ENG" (engage) and "DIE" (disengage).
/ Field Boss 254
Ok so I did some checking. I found the other lever. It seems to function properly (feels like it catches on the up or down position).
But the speed selector
Just moves freely no feeling of engagement. This weekend I will try to do some more checking. Hopefully it's just a pin issue
/ Field Boss 254 #6
/ Field Boss 254
Thanks for the info. I will do a little more checking. I really need to get ahold of a manual or diagram. Sent you a PM "Affordable"
/ Field Boss 254 #8
I did not get anything, just call the Shop 979-865-4002
Tommy
Affordable Tractor Sales
/ Field Boss 254
Tommy,
Tried to send you a PM again.
/ Field Boss 254
Ok, quit worrying about the PTO for a while, but now have an issue. Did get more info on tractor though.
So from my research, I've found it's actually a Feng Shou tractor.
Made in the Jianxi tractor plant.
Issue now is that I've lost the brakes. Does anyone have a parts list, or idea where I should look? Are changing/replacing brakes a huge job?
Also, the ignition switch hangs up, guess I need to find one of those somewhere.
PORTA POTTY (A68842)
2019 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2019 CATERPILLAR...
RIDGID AIR COMPRESSOR (A68842)
RIDGID AIR...
2013 RANCO BELLY DUMP (A67714)
2013 RANCO BELLY...
2017 Ford Explorer SUV (A66738)
2017 Ford Explorer...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
