Field-attachable / Reusable hydraulic fittings - Pros & Cons
   / Field-attachable / Reusable hydraulic fittings - Pros & Cons #11
I've been using reusable fittings for over 30 years. Never had a problem. You might take a look at ready made hoses at surplus center if the lengths fit your application. They're cheaper than you can have them made locally, or even make yourself.
   / Field-attachable / Reusable hydraulic fittings - Pros & Cons #12
the "phase out" is due to supply and demand too.....as a business decision, the crimped ends are cheaper to purchase and quicker to install.....for DIY they are cost effective, so stocking up may be a good option
Less different styles of field attachable ends avail also due to supply and demand
As far as litigation the name of these fittings used to be called "reusable" but now all hose mfg's want no old fittings/hose to be reused in case they are rusted, damaged or installed incorrectly...thus the "field attachable"
   / Field-attachable / Reusable hydraulic fittings - Pros & Cons #13
If I am not mistaken some of the mfg's also call them field emergency fittings!
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
2016 Chevrolet Malibu Sedan (A53424)
2016 Chevrolet...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
