Field-attachable / Reusable hydraulic fittings - Pros & Cons
   / Field-attachable / Reusable hydraulic fittings - Pros & Cons #11
I've been using reusable fittings for over 30 years. Never had a problem. You might take a look at ready made hoses at surplus center if the lengths fit your application. They're cheaper than you can have them made locally, or even make yourself.
   / Field-attachable / Reusable hydraulic fittings - Pros & Cons #12
the "phase out" is due to supply and demand too.....as a business decision, the crimped ends are cheaper to purchase and quicker to install.....for DIY they are cost effective, so stocking up may be a good option
Less different styles of field attachable ends avail also due to supply and demand
As far as litigation the name of these fittings used to be called "reusable" but now all hose mfg's want no old fittings/hose to be reused in case they are rusted, damaged or installed incorrectly...thus the "field attachable"
   / Field-attachable / Reusable hydraulic fittings - Pros & Cons #13
If I am not mistaken some of the mfg's also call them field emergency fittings!
HYUNDAI HL760-9A LOADER (A52705)
HYUNDAI HL760-9A...
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A54757)
UNUSED RAYTREE...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2001 MACK CH613 DAY CAB (A54313)
2001 MACK CH613...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
