Fiberglass rebar for garden stakes?
   / Fiberglass rebar for garden stakes? #3
I use 1/2" diameter generic concrete steel rebar from Lowes in my garden. Work great. Have used same 36" to 120" rebar sections for 25 years. I cut rebar with a Sawzall. A manual hacksaw will cut 1/2" rebar too, more slowly.
   / Fiberglass rebar for garden stakes? #4
Even UV coated fiberglass do not last that long. I would stick with steel, rebar, or vinyl coated steel, instead, unless you expect to run your tiller over the stakes.
All the best,
Peter
   / Fiberglass rebar for garden stakes? #5
I recall running my hand down an old fiberglass driveway marker stake one time. YEOUCH! YEOWY! OWW! :ROFLMAO:
I was picking fiberglass splinters with a magnifying glass and tweezers that night.
As mentioned, steel rebar is cheap, lasts for decades, easily bent into shapes, and easy to cut with bolt cutters or hack saw.
   / Fiberglass rebar for garden stakes? #6
Best tomato support I've ever used is a heavy duty metal cage shaped like a cone. I've made round cages out of field fence, but they don't nest together for storage in the winter like the cone shaped ones.
   / Fiberglass rebar for garden stakes? #7
Years ago I planted a small stand of bamboo that I could contain by mowing around it. Bamboo makes great garden stakes and tomato cages.
   / Fiberglass rebar for garden stakes? #8
Not sure if it would be similar but fiberglass electric fence posts you have to wear gloves around or you are trying to find invisible splinters.
   / Fiberglass rebar for garden stakes? #9
We use the sunguard 3/8 smooth fiberglass post for rotational grazing from TSC.
Sometimes they get hit and brake off the bottom 5" or so.
I cut them off and sharpen them on a belt sander and handle them without worry of splinters on the top section. We use these in the garden to mark rows and tie up plants all the time.
If the ground is soft and I have my carhartt on I just use my shoulder against the top while gripping and shoving down with bare hands to put them in the ground.
Otherwise we only use a rubber mallet to put them in the ground if its hard or frozen. Some of them have to be over a dozen years old now. Use a metal hammer one time and you will always be getting splinters.
   / Fiberglass rebar for garden stakes? #10
Fiberglass rods will eat you up once the coating degrades. I’d find something else.
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
2020 Polaris Pro XD (A51573)
2020 Polaris Pro...
