Fiat 640
/ Fiat 640
Check on left of engine at flywheel . Their is a window...the casing has a pointer on. Turn the flywheel till you get to the marks for the injectorpump fitted to the engine. Like if you have a CAV pump then the mark must also be CAV.
Remove the pumpgear and turn the pumpshaft till it locks up at number 1 outlet.
Install the gear without turning the pumpshaft.
2014 GRADALL XL3300 II MOBILE EXCAVATOR (A65056)
2014 GRADALL...
CAT 930 Coupler (A68134)
CAT 930 Coupler...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
Unused 2023 Hustler Regener8r LM630 Hydraulic Chain Harrow Tractor Loader Attachment (A66734)
Unused 2023...
2023 Polaris Utility Cart (A66738)
2023 Polaris...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
