Fiat 640
/ Fiat 640
Check on left of engine at flywheel . Their is a window...the casing has a pointer on. Turn the flywheel till you get to the marks for the injectorpump fitted to the engine. Like if you have a CAV pump then the mark must also be CAV.
Remove the pumpgear and turn the pumpshaft till it locks up at number 1 outlet.
Install the gear without turning the pumpshaft.
1991 BRENNER TANK TRAILER (A67714)
1991 BRENNER TANK...
2013 MACK CHU613 WINCH TRUCK (A67714)
2013 MACK CHU613...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
CAT 966G Grapple (A68134)
CAT 966G Grapple...
2025 32in Bucket Mini Excavator Attachment (A66734)
2025 32in Bucket...
Unused 2023 Monroe Tufline TW92420 9ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
