few 4410 hydraulic questions
   / few 4410 hydraulic questions #1
ohioboy
I've installed a solenoid selector valve on my tractor for grapple on loader. I bought it from baileynet (can't locate part no. at moment) and it was less $ than surplus center, works well, but there's a little issue...
In addition to -6 inputs/outputs it has an sae-4 drain port for fluid that somehow gets past spool.
It pisses a little fluid from here.
Other than plumbing this port back to some type of tee arrangement at rear end vent/fill, is there another more convenient place further forward to plumb it to tank?
I've got ePowerReverser trans
Also, who's/which top n tilt do you guys recommend?? And which/who's tip for pioneer coupler??
Thanks in advance!
   / few 4410 hydraulic questions #2
Looks like key#4 in this picture would work
Thanks, I'll look there. I should be able to plumb a 1/4" line to dump there.
I checked out the suggested location and its on left side of machine essentially above rear axle.
Does anyone see why I can't/shouldn't plumb this dump line to the valve manifold's tank galley?
The valve manifold is only a few feet behind loader/selector valve on right side of transmission housing.
I'm assuming it's unrestricted to tank, i.e. no/little pressure
I'd have to source metric adapter fitting for that connection.
Thanks in advance again!!
   / few 4410 hydraulic questions #5
Is there any reason you ca 't just plug the -4 so once it is full and is just full of what slipped past the spool?
Tried that. Still wants to push fluid past plug which lends me to believe it needs to be plumbed to tank.
Trying to compress/fight fluid on the wrong side of seal can't be a good thing for longevity.
   / few 4410 hydraulic questions #7
Just send the out flow from that port back through the closest return hose.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
SKID STEER BRUSH ATTACHMENT (A53843)
SKID STEER BRUSH...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2012 KENWORTH T800(INOPERABLE) (A53843)
2012 KENWORTH...
WOOD GRABBER FOR MINI EXCAVATOR (A53843)
WOOD GRABBER FOR...
