Fertilizer/seed spreader for 3039R cab model
   / Fertilizer/seed spreader for 3039R cab model #1
Hayseed Andy
Lake County, Florida
JD Z915B ZTR
I have been doing research for a spreader for fertilizer and seed for a 3039R cab model. I don't want want the tow-behind model. In looking at literature, videos, etc, it seems most of the tractors running the spreaders are ROPS models. I anyone familiar with utilizing these with a cab model? I am sure it's just a coincidence, however any input is appreciated.
   / Fertilizer/seed spreader for 3039R cab model #2
Suspect they are mounted on the 3ph, so would not make a difference whether cab or open station. Could be wrong too.
I had the same thoughts, however since I couldn't seem to find any videos or photos with a cab, I began to wonder. Even the guy at the local shop said he was going to double check.
   / Fertilizer/seed spreader for 3039R cab model #4
Which spreader(s) models are you looking at?
   / Fertilizer/seed spreader for 3039R cab model #6
It will not make any difference between Cab or ROPs to use a spreader. Around my area, Cab tractors probably outnumber ROP Tractors about 3 to 1; and most are using spreaders right now for spring planting. Some landowners use their own tractors, but most hire contractors for planting.
Perfect. Thank you.
   / Fertilizer/seed spreader for 3039R cab model #8
I have a spreader on my Branson 4815 cab right now. It works fine. I just leave the back window open to reach the spreader handle. The only potential issue is do not raise 3pt or the spreader will take out the back window. :oops:
I'd have to tell the boss I needed more access to the handle. Not that she would believe it, of course.
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Charlotte County (A50323)
Charlotte County...
