Fertilizer/seed spreader for 3039R cab model
   / Fertilizer/seed spreader for 3039R cab model #1
Hayseed Andy
Lake County, Florida
JD Z915B ZTR
I have been doing research for a spreader for fertilizer and seed for a 3039R cab model. I don't want want the tow-behind model. In looking at literature, videos, etc, it seems most of the tractors running the spreaders are ROPS models. I anyone familiar with utilizing these with a cab model? I am sure it's just a coincidence, however any input is appreciated.
   / Fertilizer/seed spreader for 3039R cab model #2
Suspect they are mounted on the 3ph, so would not make a difference whether cab or open station. Could be wrong too.
I had the same thoughts, however since I couldn't seem to find any videos or photos with a cab, I began to wonder. Even the guy at the local shop said he was going to double check.
   / Fertilizer/seed spreader for 3039R cab model #4
Which spreader(s) models are you looking at?
   / Fertilizer/seed spreader for 3039R cab model #6
It will not make any difference between Cab or ROPs to use a spreader. Around my area, Cab tractors probably outnumber ROP Tractors about 3 to 1; and most are using spreaders right now for spring planting. Some landowners use their own tractors, but most hire contractors for planting.
Perfect. Thank you.
   / Fertilizer/seed spreader for 3039R cab model #8
I have a spreader on my Branson 4815 cab right now. It works fine. I just leave the back window open to reach the spreader handle. The only potential issue is do not raise 3pt or the spreader will take out the back window. :oops:
I'd have to tell the boss I needed more access to the handle. Not that she would believe it, of course.
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2015 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2015 FREIGHTLINER...
