Ferris is3000 locked up
/ Ferris is3000 locked up #1
jim66
Corcoran, Mn
ferris is3000
i have an older ferris zturn mower which has been running well but just today it died and wont start. I can turn the flywheel by hand counterclockwise but not clockwise. When the starter tries to turn it, it moves 3-4 inches and stops. I've tried with the spark plugs pulled and no difference. The pistons seem to move in the cylinders ok. Could this be related to a hydro problem somehow. When it died for the last time left control lever was shaking a bit.
/ Ferris is3000 locked up #2
Welcome to TBN
Slack off drive belt tension or remove belt from crankshaft drive pulley.
The clutch for the pto drive pulleys is disengaged and the belts are not trying to turn.
Thanks TxJim
I think this may be one of those good news bad news things. I removed the belt that drives the two hydraulic pumps and now the engine turns freely. That being said when i turn the hydro pulley on the right it turns freely. When i turn the one on the left it only move about a quarter turn. Since I don't really know how they're supposed to work I'm only guessing this is a bad thing.
/ Ferris is3000 locked up #5
Sounds like your pump let out its magic smoke. Guessing something fragmented causing it to bind. Definetly cheaper than a new engine but it still sucks.
I'm definitely a rookie when it comes to this kind of stuff but I'm thinking I might be able to replace this myself. Anyone have suggestions or trouble spots I should look for. Also a good place to order parts. I'm finding most pumps are over $500 and this is just for home use.
/ Ferris is3000 locked up #8
If the rest of the mower is in good shape, I would bite the bullet and replace the defective hydro unit at whatever the cost. It will surely be better than buying a new mower.
Have you been changing the hydro oil and filter as recommended?
Not for a couple of years. It's only used around the house but apparently I haven't changed it enough.
Is there anywhere to get a service manual for this. From what I have found online removing the pulley from the hydro might be the biggest challenge.
John Deere 310K Backhoe (A65579)
John Deere 310K...
2026 Electric Tricycle (A64194)
2026 Electric...
(2) Firestone Tires (A65640)
(2) Firestone...
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
1999 Nabors Chip Trailer (A62613)
1999 Nabors Chip...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
