Ferguson won't start
   / Ferguson won't start #11
Re: Ferguson won\'t start
good, glad to hear shes up and running.
   / Ferguson won't start #12
Hey Rich, I have been thinking about the moisture problem you have been having with the fuel tank in your Ferggie. I always thought it was strange that you had to add dry gas all the time. Then I thought about how the tractor is set up. You have the fuel tank under the hood, but over the top of the motor. Now the filler cap is covered by the hood, so no water should drip into the tank. Then it hit me. These tractors have a wide, long, shallow tank, right? I am thinking the heat from the motor baking the bottom of the tank, and the colder top of the tank, you got the perfect environment for condensation. I wonder if these tractors had, at some time, a heat shield between the tank, and the motor? I assume yours does not right? Now I would bet if you added some type of a heat shield, or used some of that foil backed insulating mat, between the tank, and anything hot,[motor, radiator, etc] it would stop, or almost stop your water problem.
That certainly makes sense, Paul. There is no heat shield on mine, or any other Fergie I've looked at, and I've looked at over a dozen. That sounds like it's worth a try, I'll see if there's room to put some kind of insulation under the tank.
Thanks!!!
   / Ferguson won't start #14
I don't know if the tanks on your fergies are vented like the tanks on our N's.. but that seems like a constant problem.. since it is a vented tank.. moist air can always find its way in...
Soundguy
   / Ferguson won't start #16
Yep, serves the same purpose. Our ford tanks have a little dome with a pin hole in it behind the gas cap... It is hard to get to so when it does get plugged, many 8n/9n/2n owners just get a vented cap.. or leave the cap loose when running... but anytime there is a hole that is a source for moisture... but hard to avoid... /forums/images/graemlins/frown.gif
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
48 Inch Farm Jack (A57454)
48 Inch Farm Jack...
7ft Titan Box Blade (A57453)
7ft Titan Box...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
