Ferguson TO-20 pto hydaulic problem
   / Ferguson TO-20 pto hydaulic problem #11
easy to test the hyds on them old fords and fergy with belly pumps.
you disengage pto, runt he hyd handle up, stick a screwdriver thru the pto then spin it by hand.... it works the pump.. thus lifting the 3pt. lets you check leaks and strength...
Thanks for that info and it makes perfect sense also. The I&T shop manual has great pictures of all the parts but must be the condensed version because nobody would ever call it wordy. Heck, only 32 pages for the entire tractor.
   / Ferguson TO-20 pto hydaulic problem #13
so simple to work on ya only need 32.. :)
No kidding and only a handful of wrenches fit everything. That's why she's down to a skeleton right now. I haven't had this much fun in years.
   / Ferguson TO-20 pto hydaulic problem #15
i remember doing a repair a while back.. and it seems 11/16 was popular!
   / Ferguson TO-20 pto hydaulic problem #16
Hi new to this ! I have a massey TO 20 with I believe a woods front loader and direct drive pump !Can these pumps be rebuilt !
   / Ferguson TO-20 pto hydaulic problem #17
stinger pump?
It was a fun and easy project to remove the hydraulic pump and rebuild it. Parts are readily available. Don't forget the rings on the upper piston as well.
   / Ferguson TO-20 pto hydaulic problem #19
i'm thinking he's NOT talking about the belly pump.. but rather a stinger pump.
though he won't reply back...
Right after I replied I re-read his post and agree with you. Since he didn't answer you I didn't ask him any more questions either.
I still appreciate your help way back when. Hope all is well.
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A54757)
UNUSED RAYTREE...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
UNUSED LANDHONOR RTH-13-2000G HYD TREE GRAPPLE (A54757)
UNUSED LANDHONOR...
(INOP) 2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DU (A51406)
(INOP) 2008...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
