Ferguson FF30 injectors
   / Ferguson FF30 injectors #11
A simple test is> take an injector out & hook it back up, outside the engine..& crank the engine & SEE if its spraying/opening.
DO NOT get near the spray.. IT WILL penetrate your skin & its a trip to the hospital for blood poisoning. NOT FUN..
Did u ever get the correct opening pressure?? 2500psi "might be" to hi..
Did u check the other injector opening pressure??
After that> its time for a compression test..
BUT IF you've BEEN starting it w/ ether, its probably to late..
I did wonder if 2500psi might be too high possibly only working after ether applied continuously. The original pressure may have been below 2,000 I have a 20tea that I could check from. The main problem was the smoke which was diesel and now is oil based - next stage will be an engine rebuild as spares are so cheap.
Just reduced the pressure to 1400psi which is what the tef20 had. Starts and runs much better. Can you find the correct setting?
I phoned Agriline products in UK and they said the pressure should be 2400 psi. Does that mean that the pump is worn out?
I havent tried your suggestion yet.
   / Ferguson FF30 injectors #14
I cant find my book.. but 1400 sounds awful low..
I would set'm at 1800 & see what that does..
I just been told by a rebuilder that the TE20 (20c) is 120ats and the FF30 (23c) is 135ats. (1763 & 1983psi) You were very close.
It appears that I have some work to do.
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A55758)
2004 Fleetwood...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2007 Mazda CX-9 AWD SUV (A55758)
2007 Mazda CX-9...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
