Fergie's in ICU
/ Fergie's in ICU #181
I've been using Stanadyne since 2006 -- it was recommended for my 2005 Jetta TDI Wagon (BEW/PD engine), so I began to use it with the LRB, adding a few ounces with each fill-up of my 5-gal diesel can. I now also use it in our 2015 MB Sprinter RV (3.0 V6).
My LRB is now at 1267 hrs...
/ Fergie's in ICU #182
I use Powerservice, it's what I got recommended by some long haul truckers for diesel.
/ Fergie's in ICU
<snip>
what additive are you using?
<snip>
The additive is some sort of Lucas stuff; sorry, don't care to run out to the shed in the rain to look. : )
Wrong! The additive is Hotshot's Secret Diesel Extreme. I had purchased a bunch of different additives/cleaners when I thought I had injector problems, and will use them all, one-at-a-time, from now on ...
/ Fergie's in ICU #184
The HS Extreme is more aimed at "cleaning" ... Like you were looking for prior, but I'm guessing your now running new injectors, I'd save that and run a tank or 2 after 250 hours ...
Should be after the 1st of the year or so, with the amount your using it ...
If you have a "anti-gel" in your collection ... I'd start using that stuff once you regularly get below 30° ...
/ Fergie's in ICU
Yes, of course the new engine came with new injectors. : )
And yes, I will start using anti-gel shortly.
What is the recommendation for "everyday" fuel additive?
/ Fergie's in ICU #186
Read up about Stanadyne -- I use it in all my diesels...
Yes, it has cetane boosters, lubricity additives, etc, but the real reason I like it is because for possible water contamination, it's designed to cause water to come OUT of suspension and get trapped in the water separator, rather than COMBINING with water and continuing through the fuel system as many additives will do.
At least that's what I remember about it. I was at a TDI Fest in Montreal in 2006 when I learned about it. It was "VW Approved."
On the Sprinter forum, there's a highly-respected Sprinter "guru" who also recommends it.
/ Fergie's in ICU #187
I switched over to Hot Shot secret EDT (everyday diesel treatment) a while ago, they also offer a EDT+anti gel. I've never used the EDT+winter defense.
Sent from my SM-S921U using TractorByNet mobile app
/ Fergie's in ICU #188
I too use the HS Everyday, or winter defense ALL the time depending on what the weather is ...
I'm not saying one brand is better than another, but I switched my semi-truck over to HS WD for the winter, company pays for it, but not in the summer ... I use to use Howes ... The IMPORTANT thing to me is ...
Both the Howes and Hotshot does this also ...
Since we are forced to use ULTRA Low Sulfur Diesel (ULSD) now, the need to put both the lubricant and the centane in to boost it back up to the level that the Japanese use, and where our engines were designed/built ... And water SEPARATION, is crucial to long pump and injector life!
/ Fergie's in ICU #189
Yes, the one good thing is I can get 50cetane min off road diesel, so thats whats in my transfer tank.
My normal day to day diesel (I drive 600+ miles a week) is a nearby station that only has 40cetane min, so I'm pretty religious about an additive.
/ Fergie's in ICU #194
How 'bout the guy I met years ago who put an injected Corvette 327 into an Austin-Healey 3000? He had to reach around the front tires to get at the plugs....
Heck- my shoehorned 455/462 Pontiac powered RX 7 has lots of room to get at the plugs, number 7 is the only one that is a bit tight due to the steering column.
ps. On the new Fergie engine -I have been wondering if it is a quieter running engine than the original was out of the gate?
/ Fergie's in ICU
The new engine is no quieter than the first one was for the first 500+ hours. But it sure is a hell of a lot quieter than she was towards the end of her death throes.
/ Fergie's in ICU
That is a lot of hours in a short period of time compared to a lot of SCUT owners. I don't think I'll do 100hrs in 4yrs with my usage.
See below posts (from the "What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY" thread Oct 31, 2024):
I have a 2022 Massey Ferguson GC 1723EB nicknamed "Fergie" after Sarah Ferguson, Dutchess of York. I also call her "my red-headed mistress".
Today is Fergie's first birthday, and she has 421 easy rough hours on her. She has had all manner of indignities thrust upon her but is holding up well.
What do you do?
I have Ellie my 2007 GC2300 with a belly mower. Just turned over 400hrs. In 17 years.
My 1725m with loader is a 2022 and has aboot 35hrs.
With that ridiculous number of hours, I'd like to tell you that I've been doing contract work for others, but the truth is that I am just a "hobby user". And it was an unusual year:
- We had knocked down over 200 trees (mostly red pines) the year before and they had to be dragged away.
- We had a bunch of ditching to do.
- We had a bunch of "landscaping" to do.
- Our 750-foot private road (with 3 houses) needed extensive reshaping.
- Our own driveway needed extensive reshaping, including removing a huge amount of concrete debris from a demo/addition 30 years ago ("seemed like a good idea at the time").
- It was fun (mostly), like playing with my own giant Tonka toy.
In the future, hours per year will drop dramatically. I'm hoping not to burn through my 10-year/2000-hour extended warranty before 2033. No plans to use this for mowing or plowing. In fact, more than 50% of the hours have been using the 60" Land Pride RB1660 back blade. The 3-point hitch and the back blade are fully hydraulically actuated with twin-tilt cylinders, top cylinder, and another cylinder on the back blade to rotate it.
I also have modified the factory optional mechanical backhoe thumb with yet another hydraulic cylinder. One of these days when I get everything working the way I want, I'll post a thread.
/ Fergie's in ICU #199
I've enjoyed that thread for sure.
I've had my TYM T224 just shy of 3 months and had to refill the fuel tank for the first time a week ago @ ~14hrs on the clock. It had ~4hrs on it when I took delivery of it.
14in Digging Tooth Bucket Excavator Attachment (A60352)
14in Digging Tooth...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
1995 Peterbilt 379 Tri-Axle Dump Truck (A59230)
1995 Peterbilt 379...
APPROX. (26) 2"X8X12' METAL FRAME WALL STUDS (A60432)
APPROX. (26)...
4 ROW CULTIVATOR FRAME (A60430)
4 ROW CULTIVATOR...
