Fender amber light on L4400 snapped off
/ Fender amber light on L4400 snapped off #1
kubota4me
USA
An orange one
I was working in some tight places with my L4400 and some tree branches busted off a fender light. Are those easily replaced or is there some cutting of wires involved in replacing it?
/ Fender amber light on L4400 snapped off #2
I don't know about the L4400, but mine were broken off when I got my tractor used. They had been replaced with amber ones from Fleet Farm (Peterson mfg). To replace them on my BX2230 was going to cost $80 a side. At Fleet Farm it cost me about $8 a side.
The wiring is different however because the Petersons have 2 elements and the wires are both hot going in with the mount being the ground. I have found that the ground through my ROPS is worthless and I had to wire a bit more, but it was a whole lot cheaper.
I don't know for sure how the Kubota's are wired, but whoever put mine on didn't read the Peterson box.
/ Fender amber light on L4400 snapped off #3
I'm sure there's a plug. If you don't mind doing a little work I'm sure you could get some heat shrink tubing and cut the plug off the factory light and use an aftermarket option for savings (may make sense if you think you're at risk of breaking another one (or two).
It bugs me that the lights are the shape they are. If they were square and aerodynamic so branches would simply slide over the top of them it would be a much better design IMO.
/ Fender amber light on L4400 snapped off #4
I have come real close to knocking mine off several times! When it happens I will be sure to wire in some cheaper alternatives that look the same. Peterson has been making lighting products for forever.
/ Fender amber light on L4400 snapped off #5
I have loosened my lights doing exactly the same. So far they have not broken. The mounts are not threaded like my old Massey so that you could screw a nut on. If I have to replace mine I will look for that kind to remount thru the fender.
2025 JMR 78in Dual Cylinder Grapple Rock Bucket Skid Steer Attachment (A61572)
2025 JMR 78in Dual...
UNUSED WOLVERINE FORK FRAME (A64281)
UNUSED WOLVERINE...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
UNUSED WOLVERINE QUICK COUPLER 8 (A64281)
UNUSED WOLVERINE...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
