Fencing question
/ Fencing question
... & Bunyip. This is a bloody interesting product. The only foam I've ever used is to plug a 'household' hole.
How did you hear about it? Research or a conversation?
stumbled across it when I was looking at post hole digging which was new to me a year ago, have used the cans to plug holes but never in bulk but have since found out the expasion rate is 20:1 and I can buy a 2 litre kit for about AU$35 plus $15 postage from Sydney.
The info here has been helpful but still don't know how big the optimum gap needs to be.
/ Fencing question #22
For dry concrete, about 3 inches. For a 4x4 pressure treated wooden post, I dig about an 8-10 inch diameter hole or whatever I can get with a standard scissor type manual post hole digger. For a 3" metal post for chain link fence, I end up with the same size hole because of the digger, but use more concrete to fill the hole.
I guess it depends on what you have to dig with. A 10 or 12" powered auger would be fine for most holes.
/ Fencing question #23
We use foam for setting our poles at the utility i work for. Works great. Only problem is getting rid of the dirt. But I致e set 100+ foot poles with foam. Our original stuff didn稚 work in water, meaning, it sit on top of the water, the water would recede, and leave a void. Our new stuff with push the water up, and out.
How long ago? I'm thinking longevity will be an issue. Ground moisture, freeze/thaw cycles, wind load coupled with the cable tension load causing movement/swaying and so on. A 100' pole is going to move around a bit over time. I see 40s leaning considerably after only a few years. Has this stuff been in use long enough to know how it will or won't decay or compress/compact over time in real life application?
I know for certain that the consumer grade canned insulation decays when exposed to any elements. So far, it seems to be OK inside walls without exposure, but it doesn't get the stresses of movement like it would around a pole in the ground.
/ Fencing question #24
They set utility poles with this in my area after the 2009 ice storm & they are still standing as straight as the day they were put in.
/ Fencing question #25
I’d say it’s probably been available to us for maybe 7-8 years. Here is the stuff we use:
Rainbow, Pole Setting Foam, 7 cubic feet (1 kit)
I’ve had to pull a few that have been foamed and it can definitely be a chore compared to a dirt tamped pole.
/ Fencing question #26
We have used foam to float our docks for years.
The blue or pink foams are generally urethane and as such do not absorb water, closed cell.
The white is polystyrene and that absorbs water like crazy, is open celled
The white would cause rapid decay of the wood in my opinion (if that is what I saw being used in the film clip)
/ Fencing question #27
that makes sense....the surface tension on a dirt tamped pole would be the circumference of the pole......the surface tension on the foamed pole would be the circumference of the foam which I'd guess would be close to twice the size of the pole.......so a lot more pulling power needed........Jack
/ Fencing question #28
The only thing I've ever packed around a wooden post is dirt. In an emergency situation, I added some gravel. The jury's still out on the gravel.
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2015 Chevrolet Express Shuttle Bus (A66736)
2015 Chevrolet...
Hydraulic Breaker Skid Steer Attachment (A66734)
Hydraulic Breaker...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2018 Chevrolet Equinox SUV (A66738)
2018 Chevrolet...
6 wheels to fit a CAT 120G (A68134)
6 wheels to fit a...
