Fencing on a slope
   / Fencing on a slope #1
Fastball
North Okanagan, British Columbia
Kubota L2900
Hi, all....am replacing some torn-down fencing on my acreage. The deer have been living on the lot, eating my apple trees, my berry shrubs - and worse of all, my wife's flowers. **** hath no fury than a gardener's flower garden defaced.
Anyways, the problem area is sloped...gradually at first, and then the last 25 feet go up at quite an angle. I know I will have to do it in sections, but my question is this....do I keep the top of the welded wire deer fence parallel with the ground, or try to keep the top dead level and perhaps cut the bottom of the fence to follow the contour of the ground? It's in the back corner, so cosmetics aren't a big concern.
Thanks for any/all suggestions..
   / Fencing on a slope #2
How tall is the welded wire, and how large are the contour changes?
Bruce
Wire is 5 feet tall...I have 10 foot poles, so I want wire at least 7 feet up. The major part is about 25 yards long with a foot or two elevation. The last 20-25 linear feet goes up 5-odd feet.
Not sure yet if I'm going to run/overlap two courses of the mesh wire to get to my preferred height...or just run one 5ft high course and then do a couple of strands of high-tensile or barbed wire to make up that 2-3 feet. **** deer will jump a 6-7 foot fence like nothing.
   / Fencing on a slope #5
I don't know enough about what you are doing to help out. But I thought I would mention that we had deer cleaning out our orchard recently. This was the first time in 30 years we had the problem - three sides were 8' chain link fence and one side was the house-yard. They were bolder I guess and came through the yard to the orchard. They only came at night. We noticed that as soon as we turned on a light they would scatter. So we put a solar motion detecting light on a pole in the orchard and that solved it for us.
   / Fencing on a slope #6
I have 2 suggestions. First, keep the fence top parallel to the ground so that the height remains consistent and they don't get a short area to step over. The second suggestion is to use 8' woven wire game fence with a strand of barbed wire at the top instead of 5' welded wire fence. The woven wire will do better in the season changes and while acdeer can clear an 8'-9' fence they need to have a good reason to do it. It'll be cheaper to go ahead and build it this way now than to have the deer laugh at you 5' fence, continue eating what they want,your wife blame you and then you have to redo it or add to it anyway.
STx - an 8-ft fence wasn't an option at my supplier. I got what was available, which was a 330 foot roll of 60-inch. I figured I'd either stack one length on top each other to get up my 8-foot target....or run a 5-ft chunk with a few strands of barbed or high-tensile wire spaced a foot or so apart on top.
   / Fencing on a slope #8
Typically you don't cut the bottom of the fence. If a little LIGHT digging needs to be done to run straightish runs that's what is done. Don't try to keep the top parallel with the ground per say as this will make for a lumpy looking fence. Keep it straight with the overall grade instead. Run what you can with the method above and keeping the top straight. Then change direction for steeper section and run that straight. Hopefully that makes sense- I may not be describing it all that well.
I'm sure you are aware but the change of directions come out best when two post and some cross braces are used. Set up a pipe or 2x4 that can pull the wire with your tractor and or come along to get it tight.
We have thousands of acres of winery vineyards in our hilly area and this method works to keep the deer out.
   / Fencing on a slope #9
Hilly areas are hard to do - and keep the fence stretched tight. It has to be tight to some degree to function right. I have some short areas at my place that are too short to feasibly stretch a fence. I put in wood posts every 8 feet and use 16 ft sections of cattle panel. These I fasten on with barbed fence staples(at least 1 1/4" or longer). When I really want to get fancy I take my generator welder and stitch the ends together. Use a bolt cutter and a friend and trim the ends so that the fence can contour the ground. It will be wavy even when you stretch it. One thing you might do is tack a top rail on the top made of 1 1/2 x 3/16 steel. You'll need a helper pretty much for the whole job but this will make a pretty durable fence that wont need constant attention. The panels run about $20 a piece at TSC or similar.
Good luck with it
When you say "straight with the overall grade", do you mean LEVEL (as in put a level on it and hit the bubble)...or do you mean to ROUGHLY follow the slope? There's a couple of sections I can't get a tractor or come-along in...so I'm gonna have to do a "good enuff" kinda job.
Ford 8340 (A53317)
Ford 8340 (A53317)
Adams Tender / Magnolia Trailer (A56436)
Adams Tender /...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
LIGHT TOWER (A56857)
