Fence Row Grass Cutter
/ Fence Row Grass Cutter #1
LeTempt
Alabama
John Deere 5065E Cab, John Deere 316GR skid steer, and John Deere 1025R
I have been thinking about building something that would cut the grass in my barbed wire fence rows. My original basic idea was to build something about like a push mower deck mounted to an arm connected to my 3 point hitch. Would have a gearbox and belt and be spring loaded so as I deck made contact with a fence post it would pivot backwards and swing out around the post. When clear of the post the spring would return the cutter deck to the original position. Probably a 18" or so cutting swath. Then I started thinking about the possibility of using a hydraulic motor instead of a belt and gearbox. Saw where someone has built something similar to this idea using a sickle mower, but I would like to be able to drive a couple miles per hour and not worry about backing up or moving the sickle in and out.
Anyone built anything like this or know of anything similar to get some ideas from?
Thanks,
Jeff
Kioti CK-30HST - 408 hours
Midland City, AL
/ Fence Row Grass Cutter #2
I saw a video on youtube that was aimed at highway depts for trimming around road signs.
Thanks. I searched youtube and found some equipment that is similar to what I was envisioning. Like this one or this one. Would make a good winter project...but RoundUp would probably be cheaper unless I can do some good scrounging.
Thanks,
Jeff
/ Fence Row Grass Cutter #6
Thanks,
Jeff
Midland City, AL
What your discribing is something like a DR Mower using either nylon string, or something a bit more durable. Instead of a gas engine it would run off a gearbox and mounted on a three point hitch off to one side the same way some tillers are made.. There may be something already out there like that.
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
Pat's QH and hydraulic top-link.
Pat's QH and...
