Fence post driver HELP please
/ Fence post driver HELP please #31
How about some of the step in fiberglass stakes? One at each end, one in the middle and two more with ropes going from ground level to the tops of the end ones.
Aaron Z
/ Fence post driver HELP please #32
If it is at a golf club do the have caddies? One of those young men/women could do it pretty easy!
/ Fence post driver HELP please #33
Forgive me for not reading all the posts (in case anyone else has made this suggestion), but if this were me, I would make a baseplate for the T-posts (maybe 18" square), and on the bottom of the plate would be (5) 6" to 8" spikes that would go into the ground (rebar would work well), one in the center and one at each corner.
As you're using these to hold banners, you could even go one step more simple and have a baseplate that has only (2) spikes into the ground; one under the post and another facing inward (towards and under the banner) about 18" or so. Doing it this way, your baseplate could be much narrower and lighter, although there would be little front/back support against wind hitting the banners.
2004 PSI M413XT Maintainer Motor Grader (A59228)
2004 PSI M413XT...
2017 Thompson 32HPU 55kW Towable Trash Pump (A59228)
2017 Thompson...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-150...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
