Fence corner brace question
   / Fence corner brace question #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
One method of securing cross brace to corner posts is to use galv. rods. I did the first one with available 3/8 rebar. Any long term problem with this alternative?
   / Fence corner brace question #2
I've used them but prefer the end plates that Tractor Supply sells. I expect that either will last longer than the brace itself.
   / Fence corner brace question #3
I have used the galv. rods with good results. Using rebar really depends on what kind of chemical treatment was used on your post.
   / Fence corner brace question #4
Oops...Mudcat's right....if you are using treated wood you need to be using galvanized materials. I've seen treated wood eat non-galvanized nails in as little as 3 years.
   / Fence corner brace question #6
Originally treated lumber wasn't as hard on iron products. Then they went with a new more evironment friendly product that ate everything but stainless or hot dipped galvanized. That has been replaced now with a newer version that's still more kind to the environment and not as harsh on steel.
I would still go with galvanized or stainless. But not because the treated lumber with destroy iron or steel fasteners.
   / Fence corner brace question #7
dmccarty said:
Was the wood wet or dry? Does it matter?
It was above ground, outside, so it got wet when it rained, but I don't think that matters....Harv pretty much said it all.
Mike
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
