FEL won't go down
/ FEL won't go down #1
EddieL
Valencia, PA
Kubota L3000DT
I think there is a problem with the valve. I lifted the bucket up, cleared the snow from the driveway and when I tried to drop the bucket the lever wouldn't move forward, moves back (up) just fine. I thought there was something wrong with the linkage but there is nothing binding up. This is a Woods BH6000. Any help is greatly appreciated.
Ed
/ FEL won't go down #2
Did you remove the cap on the bottom of the spool?...it sounds like the float detent mechanism may be the culprit...
/ FEL won't go down
The only thing I did was ask what to do here. If I remove the cap will that release pressure and the bucket fall down and leak oil all over? By tomorrow the bucket may be an the ground so I can take a closer look.
/ FEL won't go down #5
Eddie with the engine off I would suggest looking at the spool movement for lift vs curl / dump. The lift spool should move travel approximately the same distance as the curl dump when shifted from the spring center position. If the distance is different this would point towards either a linkage problem or the centering spring assembly falling apart or their is ice , crud etc. in the can that covers this assembly The centering spring assembly is located on the opposite end of the spool from the shift linkage.
Is their any name plate on the valve? If yes post that information and someone might be able to provide information on how to remove this cover and what the components should look like. Some assemblies are held on with a bolt others via snap rings, etc.
/ FEL won't go down #6
No, baring a catastrophic failure in the valve body...removing the cap on the bottom of the spool will not cause any fluid loss...what you might find is some moisture that has condensed in the cap and caused the float detent mechanism to rust to the point that some of the rusted or corroded detent parts are blocking the spool from moving...If there are any loose parts in the cap...it (the detent mechanism) needed to be addressed anyway...
It's prudent practice to occasionally remove the caps on SCVs to check for moisture and lube any detents etc...
/ FEL won't go down
Thanks, I'm thinking it is the moisture that froze. I keep it in a heated garage and it worked fine this morning. I'll take a look at it when I get home from work.
/ FEL won't go down #8
Glad to hear it...FWIW...some guys drill small weep holes in the bottom caps...
/ FEL won't go down #9
If it works after being warmed back up I think you will have your answer.
/ FEL won't go down #10
Take the wife’s hair dryers and SET it on high heat and aim it at the caps on the spool valve. Sounds like you have water in your hydraulic fluid and this has frozen inside the valve due to cold weather.
2024 DODGE TRUCK BED (A65643)
2024 DODGE TRUCK...
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2019 CAT 259D (A60462)
2004 John Deere 4720 (A60462)
2004 John Deere...
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
