FEL Wont Dump.
/ FEL Wont Dump. #1
CWKUB
kubota l6250
my hydro fluid is full. i have tried bleading the line to make sure there is no air in it. But i took and had my younger brother pull the lever to dump it, why i was pulling down on the bucket. it was tuff but finally it gave and broke past a point that it started workin on its own. but when it gets half way back up it will not dump unless i pull on it. I also dis-connected both cylinders from the bucket, to see if they both would extend. ( while in the seat ) the cylinder on the right would only extend 8 or 9 inches. the one on the left wouldnt even budge. :mad:
/ FEL Wont Dump. #2
What tractor and loader do u have.
/ FEL Wont Dump. #3
I am going to give credit to another member who pointed this out. Disconnect your quick connects clean them etc and reconnect them. I believe there is a build up dirt which is restriciting the oil flow.
Craig Clayton
/ FEL Wont Dump. #4
Craig Clayton
Yes, that is a very common problem...90% of all "won't dump" or "won't raise" problems are caused by QD's that are slightly unseated.
/ FEL Wont Dump. #5
Or frozen. Tractors do weird things when it's cold out
/ FEL Wont Dump. #6
Hasn't happened to me personally, but I've read on here where they can get bent and it results in the same thing.
/ FEL Wont Dump. #7
Had my Kubota not want to curl or dump once. A quick check found that the 3PH control (quarter inching type) was in the lift position and the hitch was all the way up, but the control lever didn't automatically return to center. Centered the lever and everything was back to normal. The linkage just needed a bit of adjustment.
/ FEL Wont Dump. #8
i once had a stick hit my qc and partially disconnect it i chased the problem for a whole afternoon.
/ FEL Wont Dump. #9
One of the cyl may have nut off the end of the piston/shaft. Does the relief activate when one of the cyl is fully extended?
/ FEL Wont Dump. #10
Another hydraulic question. Just took delivery of a BX2360 and spent 2 hours this morning clearing snow from my driveway. My question is: does it damage the hydraulic system/cylinders if when I dump the bucket, I leave the hydraulic gear engaged for a couple of seconds after the cylinder reaches it's limit? Hope that makes sense.
/ FEL Wont Dump. #11
What hyd gear? Are you saying that if you hold the levers at full dump more than usual would it hurt anything. The relief will activate and protect the pump, and some heating of the fluid will occur. It just doesn't make sense to hold the lever fwd after the bucket has dumped.
/ FEL Wont Dump. #12
I agree that it doesn't make sense, but I'm just getting used to working all 4 positions on the FEL as well as the forward/reverse of the tractor. Guess I'm not much of a multiple-tasker. Just want to ensure that I'm not doing irreparable damage by holding the lever a couple of seconds too long.
/ FEL Wont Dump. #13
You may have a blown piston seal on the right hand side.
/ FEL Wont Dump. #14
At least one cyl is bypassing fluid, which will affect the other one. Have you dismantled any of the cyl?
2019 Ford Fiesta SE Hatchback (A64557)
2019 Ford Fiesta...
2017 Link-Belt 350X4 Hydraulic Excavator (A64553)
2017 Link-Belt...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
2012 Ford F-450 Knapheide Service Truck with Liftgate (A64556)
2012 Ford F-450...
2023 CATERPILLAR D3 CRAWLER DOZER (A65053)
2023 CATERPILLAR...
(2) RIMS FOR 10 LUG HUBS (A64278)
(2) RIMS FOR 10...
