Loader FEL very slow to tilt down
   / FEL very slow to tilt down #1
Blue_Sky
Lower Alabama
2006 2615 4WD Mahindra
My '06 2615 ML 106 FEL is extremely slow to tilt down and will not tilt all the way down unless the tractor is off then it will tilt down w/o problem. Everything else works fine on the FEL. Any ideas??
   / FEL very slow to tilt down #2
Start with the easiest first. Disconnect and reconnect quick couplers.
That did it! thanks
   / FEL very slow to tilt down #5
That is fantastic!
   / FEL very slow to tilt down #6
If it happens again..............I would change the QDs. I had to do it on the remote QDs to my backhoe. The little springs in the QDs get weak over time. My BH would pop the QD just enough to not connect fully, yet still be connected.
hugs, Brandi
hugs, Brandi
Thanks!
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
EVINRUDE OUTBOARD MOTOR (A58374)
EVINRUDE OUTBOARD...
2015 Hoist P360 36,000lb Diesel Forklift (A55973)
2015 Hoist P360...
2013 Cummins DSGAB 125kW Standby Diesel Generator (A56857)
2013 Cummins DSGAB...
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
