FEL Stuck...HELP!
/ FEL Stuck...HELP!
Thanks Granddad4 and TMGT.............another senior moment. My "IIRC" was wrong as you pointed out. Geeze, after reviewing the FEL manual, that's what it says...it's the last thing one does. Chit, that was a stupid and expensive mistake. I don't even want to know what new panels/grill would cost.
The tractor is in my garage now, the FEL is up on its stands, the parts are laid out on a table and I will survey the damage and the repair needed tomorrow.........enough for today.
/ FEL Stuck...HELP! #22
The more senior I get, the more of those moments I have, too. At least I still successfully get dressed on my own in the morning. Most of the time anyhow. :D Glad you were able to get it untangled.
/ FEL Stuck...HELP! #23
It's frustrating. I managed to get mine into only one of the side panels. It missed one of the rear lower guides and got cockeyed. I caught **** also getting it off and back on correctly by myself too.
I was able to take the panel off and hammer the dent out with a block of wood as backer and hammer. It's not noticeable but to me.
I had less than 40 hours on it when this happened.
/ FEL Stuck...HELP! #24
I removed my FEL once on dirt. Never again. The stands were down, but one settled more than the other. Now it's always on concrete. Hope it isn't too high priced for ya.
/ FEL Stuck...HELP!
End Of Story......Kubota built the grill and side panels out of good stuff. The cave in and dents were pushed out by hand and some had to be tapped out with some care using a ball peen hammer.
Unless I have another senior moment, the FEL mounts on/off just like the directions indicate....a piece of cake.... if you are on level concrete.
Thanks again y'all
/ FEL Stuck...HELP! #26
Just curious, but:
Could someone put enough ballast in the bucket so that no weight is on the loader arms, and then use hydraulics to lift the arms?
How do you lift the stands if it's not pinned in? Isn't there weight on them until loader arms take load off them?
That's what I would have done, and how I got it would be to throw a 2x12 in the bucket ( so that only the end is in the bucket and it extends outward like a boom pole ) and drove my truck on it.
/ FEL Stuck...HELP! #27
There was a post a few weeks ago where someone had a brand new BX and they had done all sorts of damage to the tractor and maybe bent the loader up some, never heard how that one came out, so don't feel to bad. I feel like an expert taking my loader off and on, it usually takes me less than 5 minutes but maybe a need to slow down and be a little more carefull.
/ FEL Stuck...HELP! #28
That's an easy fix. It doesn't appear jammed in place. Have two friends grab a loader arm, pick up, and back the tractor out. While holding the arms, tilt it up high enough to pull out and lock the loader legs. The loader isn't that heavy. On my last B2620, I'd lift up the arms from in between myself to get the loader on my homemade dolly.
/ FEL Stuck...HELP! #31
The loader is a real pain if your tractor and FEL are not on the same plane when attaching or removing. I've wrestled with it enough to make sure it is now. But as far as stupid things go......
When I first got my tractor I was moving some dirt piles around some rough ground. Everything was going well until I tried to dump a bucket too fast with one wheel in a small hole. Suddenly I was on my side. Scared the **** out of me. I had only made one payment at this time and I was afraid I had done some real damage.
After panicking for a while I went in the house to get my wife for some help trying to right the tractor. When I went back outside I noticed one thing that surprised me more than anything....none of the tractor body had touched the ground, just the bucket. The turf tires are wide enough to keep the entire tractor from touching.
No damage whatsoever. Anyway, after a well place jack against the FEL mounting bracket and a strong strap affixed to a tree we were able to right the machine. I wasn't hurt but a bit scraped up from jumping clear, the tractor was not damaged and I learned a valuable lesson in loader operation.
Since then I have purchased a ballast box which I use when not using the box blade, the rops is ALWAYS up when using the fel and I am careful when going into unfamiliar territory.
And sometimes the loader is still a pain in the *** to take off and on.
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
JOB BOX (A62130)
JOB BOX (A62130)
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
DELTA RADIAL ARM SAW W/ ELECTRIC BRAKE (A62131)
DELTA RADIAL ARM...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
