FEL Snowplow
/ FEL Snowplow #1
JasonL
Pendleton, IN
JD 4110
I just finished making a quick attach for a snowplow for my JD 4110. I recently installed a diverter valve, so I will control the angle with that. I picked up a somewhat abused 7' Western (I think) snowplow locally for $100. I cut it down to 5' I bought some hooks and pins from JD to make the quick attach. I started with the mounting bracket that was already on the plow, and fabbed up the rest.
/ FEL Snowplow #2
Looks good!
How about a picture of the valve, I was thinking of doing that sometime.
/ FEL Snowplow
I read with interest the threads concerning whether a FEL plow needed to float or whether to run in float. I decided I would give myself the option, so I worked up a sliding tube system that I think will work. Basically, the plow hangs on the horizontal bar. Then when lowered to the ground it can float up about 7" It needed 2 pivot points to allow this. See following picts.
/ FEL Snowplow
Closeup of upper pivot...
/ FEL Snowplow
Close up of lower pivot point weldded to existing blade...
/ FEL Snowplow
Here is a picture of the plow in a position to apply down pressure...
/ FEL Snowplow
Here is a wider angle of the entire plow. It's amazing what a little paint will do! /forums/images/graemlins/smile.gif
/ FEL Snowplow
Since these pictures were taken, I welded the skid shoe brackets back on and put on the cutting edge. I also cut a section of horse stall mat for a rubber edge. The cylinders that came with the plow were in pretty bad shape, so my brother-in-law is rebuilding them for me. It snowed about 2" here this morning so I tried er out. Appears to me as if it will do! Time will tell. THANK You to everyone here on TBN whose ideas I stole and/or modified! Jason
/ FEL Snowplow #10
All these pictures of Snow Blades. /forums/images/graemlins/grin.gif
Nice Job. /forums/images/graemlins/cool.gif
The way snow has been coming down today. I'm going to have to put mine on. /forums/images/graemlins/wink.gif
/ FEL Snowplow #11
Looks Great! Good idea for the float also.
/ FEL Snowplow #12
Jason I like it too. And I'm sure you'll get more than a few chances to use it this winter. Let us know how it works out.
2022 EZ-GO ELITE...
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A67147)
1997 KENWORTH T300...
2011 Ford Crown Victoria Sedan (A64557)
2011 Ford Crown...
Chevrolet Metal Tailgate Metal Decorative Sign (A64557)
Chevrolet Metal...
Ground Protection Mats (A64194)
Ground Protection...
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
