FEL Snowplow
/ FEL Snowplow #1
JasonL
Pendleton, IN
JD 4110
I just finished making a quick attach for a snowplow for my JD 4110. I recently installed a diverter valve, so I will control the angle with that. I picked up a somewhat abused 7' Western (I think) snowplow locally for $100. I cut it down to 5' I bought some hooks and pins from JD to make the quick attach. I started with the mounting bracket that was already on the plow, and fabbed up the rest.
/ FEL Snowplow #2
Looks good!
How about a picture of the valve, I was thinking of doing that sometime.
/ FEL Snowplow
I read with interest the threads concerning whether a FEL plow needed to float or whether to run in float. I decided I would give myself the option, so I worked up a sliding tube system that I think will work. Basically, the plow hangs on the horizontal bar. Then when lowered to the ground it can float up about 7" It needed 2 pivot points to allow this. See following picts.
/ FEL Snowplow
Closeup of upper pivot...
/ FEL Snowplow
Close up of lower pivot point weldded to existing blade...
/ FEL Snowplow
Here is a picture of the plow in a position to apply down pressure...
/ FEL Snowplow
Here is a wider angle of the entire plow. It's amazing what a little paint will do! /forums/images/graemlins/smile.gif
/ FEL Snowplow
Since these pictures were taken, I welded the skid shoe brackets back on and put on the cutting edge. I also cut a section of horse stall mat for a rubber edge. The cylinders that came with the plow were in pretty bad shape, so my brother-in-law is rebuilding them for me. It snowed about 2" here this morning so I tried er out. Appears to me as if it will do! Time will tell. THANK You to everyone here on TBN whose ideas I stole and/or modified! Jason
/ FEL Snowplow #10
All these pictures of Snow Blades. /forums/images/graemlins/grin.gif
Nice Job. /forums/images/graemlins/cool.gif
The way snow has been coming down today. I'm going to have to put mine on. /forums/images/graemlins/wink.gif
/ FEL Snowplow #11
Looks Great! Good idea for the float also.
/ FEL Snowplow #12
Jason I like it too. And I'm sure you'll get more than a few chances to use it this winter. Let us know how it works out.
PALLET OF AXLE TAKE OFF'S & CYL (A64278)
PALLET OF AXLE...
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
2025 FABRIQUE VICTV714TA2 T/A  14FT ENCLOSED TRAILER (A67148)
2025 FABRIQUE...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2013 KENWORTH T800 BOBTAIL VACUUM TRUCK (A65643)
2013 KENWORTH T800...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
