FEL Quick Dump
   / FEL Quick Dump #1
BIKER BOB
Raymond, Maine
Mahindra 3215
Hi,
Just a question about the dump speed on the ml 111 FEL on my 3215. The decal shows that moving the fel control lever all the way to the right will allow the bucket to dump more rapidly, however all the way to the right is regular speed. I can find a spot somewhere in between full right and normal position that I can find "quick dump". Not a big deal but somewhat of a pia, being able to find it consistently takes some getting used to. Having the "quick dump" feature working the seemingly correct way would be nice. Is this just me or is something else going on here? I have taken a look at the hoses, they seem fine and in the correct positions, maybe it is something in the valve body itself?
   / FEL Quick Dump #2
My 4035 is the same way, with an ML120 loader. All the way to the right is supposed to be "regen" or fast dump mode, but in between seems to work better.
   / FEL Quick Dump #3
you have to push it past the first stopping point... like when you engage the float by pushing all the way up past the breaking point
   / FEL Quick Dump #4
Yours actually has a slow and high speed usage setting on the handle.. you just lift and turn the collar . Pretty cool system but I always keep them on the more touchy setting
   / FEL Quick Dump #5
I've never heard of this. Are you talking about the handle locking collar?
   / FEL Quick Dump
Thanks for the input, I'll check it out shortly. It is finally past the freezing point here (almost 50) it makes it a little more pleasant being outside. More snow on the way for the weekend!
   / FEL Quick Dump #7
yes you can turn the collar to change the reaction of the loader. One is for when your working the handle fast it will slow the reaction speed. and the other make the loader much more touchy. They label it as low speed and high speed if im thinking right
   / FEL Quick Dump
I just went out to "play" with the tractor, and couldn't find the collar that you might be talking about. The only thing I can see is the "locking" collar for keeping the handle in a neutral position. I also tried pushing it as far right as it will go. The same thing, the fast dump mode seems to be before all the way right!
   / FEL Quick Dump #9
My Max25 has the same decal, and the same frustrating result. Even when I find that sweet spot, it's not all that fast. Seems when i move the loader handle it goes Slow/Faster/Slower.
I've read some posts on this in the past, and it seems this is the common consensus for most Max owners. (likely a different valve than yours, but sounds very similar)
-J
   / FEL Quick Dump #10
Ok I just went and checked one out to be sure the collar doesn't turn it slides up and down to choose the setting. You can have it all the way up in the first position then slide it down for the second then further down to lock it. I apologize for the confusion
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2015 Kubota RTV-X1100C (A52748)
2015 Kubota...
