FEL Problems 250TL
   / FEL Problems 250TL #1
rattletrap
U.P. Michigan
New Holland T2310
I am having problems with the loader on my T2310.
The arms work fine, but I am having problems with the bucket circuit.
When I dump the bucket it dumps, but there is no pressure to speak of... it will not pick the front end up. When I have the bucket tilted down and lower the arms the bucket will not attempt to stay put even if I hold the control in the dump position.
When I curl back from dumped, the bucket will come back to level and stop there. It will not move any further than level at all.
When I have the bucket either partially dumped or fully dumped and I move the control to regen or "fast dump" the bucket curls back instead of dumping. :confused:
The mechanic I talked to thought the nut that holds the head on one of the bucket cylinder rods may have come loose/off so I took both cylinders off and dissassembled them... neither one had a loose nut or anything internally wrong. The packings are like new yet.
The dealer is going to call me back with more troubleshooting steps, but in the meantime I figured I'd run it by my fellow members.
Maybe I have something wrong in the control valve??? What are your thoughts?
   / FEL Problems 250TL #2
I know of one other person with a similar issue who has had no satisfaction from his dealer in fixing this problem. I can understand your frustration and can only assume it is a faulty joystick valve. I hope your dealer is able to solve the problem.
Boy I feel like an idiot.... Went back to the tractor and put my cylinders back on, and figured I'd have one last look before I got out the book of matches. One stupid quick coupler wasn't fully seated!!!! It looked like it was, but it wasn't. I should've checked them all by manually unhooking and hooking them back up. It was the second one up from the bottom.... how a snipe got up in there around all the framework, etc. is beyond me.
I guess it's a little reminder after the upside-down-no-good week i've had that not everything that goes wrong is catastrophic.
As far as my dealer goes, I really like them. They are usually quick on the draw to give me information, and a fair price on the things I need.
Thanks much! Have a good one :)
78'' skid steer bucket (A53421)
78'' skid steer...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2010 PETERBILT 367 HOT OIL UNIT (A53843)
2010 PETERBILT 367...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53473)
2011 New Holland...
2012 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2012 DRAGON...
