FEL pins- source?
/ FEL pins- source? #1
OldTrix
none
I discovered some of the slop in my FEL today, seems the pins have a bow to them. The PO of this thing must have been a real genius.
Anyhoo, can I just trot down to Tractor Supply and match up a new set? Or, are these specially hardened/sized factory parts? They don't look special at all, not even hardened.
FEL is on a Mahindra 2665
/ FEL pins- source? #2
would say they probably brand specific. My loader is a Rhino and measured o.d. of pins. looks like they are Rhino specific. Not sure you can find them at TSC or Rural King
/ FEL pins- source? #3
Bent pins are prob just the start of the problem. Bent pins usualy means you have oval holes.
/ FEL pins- source?
Yeah, I figured that as well. Weld and rebore?
Enclosed Trailer with Lube System (A62613)
Enclosed Trailer...
LOOK! (A63109)
LOOK! (A63109)
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
