FEL on F-Series
   / FEL on F-Series #11
Very nice. What's that debis in the background?
Eugene
   / FEL on F-Series #12
My F17 D came with a Nuco 48" bucket No rip teeth. It works fine.
   / FEL on F-Series #13
My F17 D came with a Nuco 48" bucket, No rip teeth. It works fine. There is Homestead in
Apple Valley Ca. They will set you up if needed.
   / FEL on F-Series #14
Hello,
I saw your post regarding the Nuco loader from Homestead tractor. I bought one last year and I was not entirely happy with it. I thought that adding my experiences might give prospective buyers some insight about their loaders.
The following were the problems I experienced:
1. It did not fit the tractor. I needed to completely rebuild the mounting brackets.
2. Front braces flexed badly. This caused the entire loader to pitch forward which tweaked the lower bracket.
I had to build the mounting brackets again.
3. Loader arms were not built parallel. They were built at different angles which caused the loader to pitch to the right. I could not fix the problem.
4. The pivot points did not have a sleeve and grease fitting. This caused the pivot points to wear excessively. I had to drill all of them out and install a sleeve with a grease fitting for the pivot pin.
5. Hydraulic hoses wore prematurely All hoses were attached with metal straps welded to the frame. When the
loader is raised and lowered, it wore the hoses out. I needed to replace several hoses and install rub protection.
In summary, the loader was poorly designed and built without regard to long term durability. I had to completely rebuilt nearly the entire loader prior to selling the tractor. Buyer beware....
   / FEL on F-Series
Thanks again guys for all the info....I haven't had much time to reply, been very busy out in the yard breaking my back doing all this work that a FEL could do in a fraction of the time. We'll it sounds like there's several options....Decision time!
   / FEL on F-Series #16
Every time I call Homestead, IF they answer the phone, I get different answers and different prices.
   / FEL on F-Series #17
The debris in the background is an old Case LA and my 6' Landpride finish mower. Are you interested in the LA? I think my friend that owns it would sell it, he's playing with Case 930's now.
   / FEL on F-Series #18
I have an FB15D with an FEL on it. Similar to the F15D just a little lower clearance, wider rear end, and heavier. I'll try and attach some pictures of the loader and tractor.
   / FEL on F-Series #19
Another picture
   / FEL on F-Series #20
3 more
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
Cattle Shute (A50515)
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
UNUSED FUTURE MINI EXCAVATOR HYD BREAKER (A51244)
UNUSED FUTURE MINI...
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A51244)
John Deere 1790 Planter (A50514)
John Deere 1790...
